Why oh why
/ Why oh why #22
Thats so weird. I dont recall any tractor ive been on, and ive operated alot over the past 40 years, not having power down loader.
It had power down, but just not quite enough uuumph to lift the front tires.
/ Why oh why
The photos I've just looked at show hydraulic cylinders with hoses connected to both ends of the loader arm cylinders.
Is yours that way? Or could someone have put single action cylinders on it, with only one hose?
Bruce
Mine has connectors both ends, they appear to be stock. I posted an update
/ Why oh why
I looked at 3 TC30's today a 2004, 2005 and a 2008 all with loaders and none of them has downward force. One of the gentlemen that buys and sells said some do some don't. Some only have single action cylinders.
/ Why oh why #25
I was thinking that you were talking about a defect, not being made as a gravity down only FEL. I can't believe such a thing would be made in modern days. Why? I sure would like pictures of such a thing.:unsure:
/ Why oh why #26
I had a Mitsubishi I think it was a 2350D the FEL was gravity down only.
It had one hyd line going to each cylinder.
/ Why oh why
What kind of pictures would you like. I can take pics of any position you want of fel.
/ Why oh why
Doesn't anyone on here have a TC30 besides me?
/ Why oh why
I had a Mitsubishi 2801FD it would lift the tractor off the ground without bucket curl. Set it on a brush pile and it would lift the tractor way off the ground. Best tractor I ever owned, should have kept it but major parts were hard to find if ever needed.
/ Why oh why #33
New seals recent, checked cylinder pressure, everything is good, but no downward force.
Sure, but just like it can't lift 3000 pounds, maybe it can't lift itself.
Maybe it has a weak pump. Internal leaks. Valve issue.
/ Why oh why
/ Why oh why #37
Have you put a pressure gauge on the system and check what pressure does it put out when you try to lift the tractor with just the lift cylinder down pressure?
/ Why oh why #38
You've heard from a couple of NH owners of similar sized machines. All of ours do not have downforce, aside from bucket curl.
/ Why oh why
That doesn't make sense if it really is a gravity down system.
I don't know what kind of system it is, but the boom has no downward force.
/ Why oh why
I know, and I thank you and the NH owners. I also looked at 3 other NH tractors and they were the same as yours, mine and the other NH owners on here.
2015 Nissan Sentra Sedan (A61574)
2015 Nissan Sentra...
(1) UNUSED 12-16.5 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED 12-16.5...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
Caterpillar 966C Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 966C...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
