pump replacement?
/ pump replacement? #1
notme
hello... i have an old case 1816 uniloader the aux hydraulic pump has a bent shaft... still works but has quite a shake to it. need to find a replacement and not having much luck.
its a borg warner pump
# on the case is S125OAK 55R
under that # is 05098
can anyone give me an idea where i might find replacement parts (shaft) or a replacement pump? its belt driven so a replacement would have to be capable of that. can anyone explain what the stamped in #s might say about this pump?
/ pump replacement? #2
Bosch Rexroth purchased Borg Warner gear pumps many many years ago and the info that I have does not exactly match the model code that you have. Attached is old data sheet that you can use for displacement and dimensional reference. The unknown appears to be the shaft.
S = External gear pump
12 = displacement range (size)
50 = 0.58 cubic inch/rev (9.5 cc)
A = SAE ORB side ports
K = SAE A-A 2 bolt mtg flange
5 = unknown shaft
5 = design series
R = clockwise rotation
  • RA10061 S12 S16 S20 S30 gear pump.pdf
/ pump replacement?
5 = unknown shaft
5 = design series
thanks alot... now i can check surplus center or maybe amazon for a cheap replacement.
so the unknown shaft what does that mean? its a 1/2 shaft? which really doesnt matter as i can match a pulley to any shaft?
/ pump replacement? #4
By unknown shaft I meant it didn’t show as an option in the data sheet
Might have some different bearing option for the side load from belt drive
/ pump replacement? #5
A bent shaft will only get worse, so good call trying to replace it. Those Borg Warner pumps are hard to find new now. I’d check with salvage yards or a hydraulic shop that can cross-match the numbers to a modern pump.
/ pump replacement? #6
Did you see the used pump I listed in one of the two other posts on the same subject?
/ pump replacement? #7
You need to find the Bosch / Rexroth number, which seems to be the defacto standard cross reference.
How I did that; I found the factory part number, and put it into google. Some suppliers advertised replacement pumps, and the ads had several numbers, one was the Bosch number.
When I had that, I put it into google and found an unused second hand one that someone was selling.
Somewhere in between, I figured out I could bolt on a 25% larger capacity one, and that was what I got.
There are different shafts; splines of various types, cones with key, or straight with key. Different flanges with different centering collars / bolt holes. And there are right and left turning options too.
As yours is belt driven, you have options if you can fabricate a bracket and fit the pulley.
For instance;
/ pump replacement?
For instance;View attachment 4454032
i can fabricate a new mount no problem. not sure how i find a matching pump tho. just using the number off the casing? didnt have much luck on google?
/ pump replacement?
thought it was a bit spendy for a used pump which might be 90% wore out
/ pump replacement? #11
You were asking for a replacement shaft for your pump and that is not how it's done. This pump may be worn out, meaning the housing is worn out, but the gearset may work in your pump. I would think that is not the case and you could ask the seller or counteroffer at half the price.
/ pump replacement? #12
The numbers on the case didn't do anything for me, despite much effort. I don't know why, but it seems that the pumps have nice numbers stamped in that don't correspond to anything.
I started at the tractor manufacturer parts book, and got their part number. When I googled that, some vendors had the pump advertised, and they also had the Bosch number.
Rather an archaic way to find a part! it worked though.
/ pump replacement?
i too looked at the parts manual for the case 1816 that this is out of. there are two pumps specified neither match the number on my pump... they were very similar though. so your saying you found some pumps? i appreciate your effort. where do i go from here?
/ pump replacement? #14
I just put the rexroth number into google, and an ebay ad popped up.
It was unused old stock, and I got it for $100 incl. shipping.
There are various flanges, shafts (straight, cone, spline), centering ring size, and most importantly rotation direction.
My tractor had 2 different pump sizes, the US version had 19cc, the EU version (mine) just 14cc. I found one with 22cc that bolted on.
QA Trencher (A64127)
ATS 13,000lb Electric Winch (A62679)
ATS 13,000lb...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2008 Ford F-350 XL (A64127)
2008 Ford F-350 XL...
2018 Bell B30E 30 Ton Articulated Dump Truck (A64194)
2018 Bell B30E 30...
