Antifreeze for my 5570 4WD
/ Antifreeze for my 5570 4WD #1
PatMiles
The Great State of Confusion
Mahindra 5570 4WD Tier 4
Noticed my radiator was low, talked with the local dealer who had none in stock and was no help as usual. What currently available antifreeze do I shop for? I plan on draining and flushing the cooling system and refilling with new antifreeze.
Thanks,
Pat
/ Antifreeze for my 5570 4WD #2
Hi Pat, my dealer said use the "green" antifreeze 50:50 as that is what it came with. eMax25 cab here....
Joe H.
/ Antifreeze for my 5570 4WD #3
Joe H.
My 2025 model 4540 came with standard green antifreeze.
/ Antifreeze for my 5570 4WD #5
CAT ELC 50/50 it's only expensive once.
/ Antifreeze for my 5570 4WD #6
For me the extended interval of the various ELC products far outweigh the additional expense.
I personally use Zerex G05 HOAT, with a 5 year interval.
/ Antifreeze for my 5570 4WD #7
I agree. I'm running a D5 a D4, a 6x6 Clark Grader and a 580k Case backhoe. I don't think that the minor additional cost is worth the cost of loosing an engine to freeze, electrolysis, etc.
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
Case Axial-Flow Combine Wheels NO RESERVE (A61307)
Case Axial-Flow...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A61568)
1999 Sterling...
2003 POLAR TANK (A60736)
2003 POLAR TANK...
2023 CATERPILLAR 926M WHEEL LOADER (A62129)
2023 CATERPILLAR...
