1970 Ford 3000 won’t move but goes into gear
   / 1970 Ford 3000 won’t move but goes into gear
Well I figured out what happened , crushed the pilot bearing when putting together 🙋🏻‍♂️ was my fault , sorry fellas ! Thanks for the responses !
   / 1970 Ford 3000 won’t move but goes into gear #22
Look at the input shaft splines -like TX Jim posted those look completely stripped off.
Here is a new 3000 8 speed input shaft pic. Shafts and splines do wear had to replace them on my Ford hydraulic pump and the collar as well. Also you can test the input shaft to wheels by turning the input shaft with a chain wrench or slide the old clutch disc on and see that is not positively engaged.
ps. I crushed a pilot bearing once as well by forcing things as a kid on a 1965 GTO. The car still drove but with clutch depressed the input shaft was not being held in true on axis alignment, it also eventually damaged some bearings in the Muncie transmission Take the time to prove the root cause on the power transfer before it goes back together - also turning the crankshaft back and forth a bit and lightly bumping the clutch pedal while getting the pilot shaft to enter the pilot bushing sometimes helps getting the last bit of engine to transmission clearance taken up without forcing things may help.
   / 1970 Ford 3000 won’t move but goes into gear #23
Hmmm....
Now that has me wondering. My old AMC Hornet. My parents had the clutch replaced, then from day 1 it would always chatter when engaging the clutch. Once engaged or disengaged it seemed to be fine, but when engaging it it would chatter some like something was out of alignment.
Obviously the shop that changed the clutch claimed it was OK, and didn't want to fix it. Ultimately I put on quite a few miles with it chattering when engaging. I don't think it ever got better or worse.
One last question , so turned out it wasn’t the clutch AT ALL , but it’s got a new one now haha it stripped every bolt or stud on the ring gear , have no clue how , but everything else looked great in the rear end , does anyone know what bolt or stud they use to attach the ring gear back onto the differential ? It’s 12 of them
   / 1970 Ford 3000 won’t move but goes into gear #25
Thank you ! I’ll look into that , I’m not worried about price I just want quality haha
   / 1970 Ford 3000 won’t move but goes into gear #27
Well I came home from work today and split the tractor again , I can do it with my eyes closed now haha and it is a defective brand new clutch , I can move the clutch forks with my hand so I’m not sure if it just jammed or something broke in it , or I read that they need to be adjusted ? Does anyone know those specs or how to do it or if I need to take it off and have someone set it up , the old clutch fingers are sticking out so it will make contact with throw out bearing but after I split it again the new fingers are in and loose so there is no way it is applying pressure on the disk 1st picture is old clutch and second pic is clutch on tractor now
   / 1970 Ford 3000 won’t move but goes into gear #28
Yes your right , when I re split it I wiped a lot of it off
   / 1970 Ford 3000 won’t move but goes into gear #30
Almost 2 years ago now I was plowing the garden and just one random pass I backed up and then went to go forward again and the tractor hasn’t moved since , no noise no nothing and clutch was pulling good and then just poor nothing , fast forward I split the tractor just got the new clutch in and flywheel resurfaced and the exact same thing ! Still will not move but goes into gear when pressing the clutch in. It feels the exact same as it did so I’m guessing it wasn’t the clutch in the first place , if anybody knows what might be the culprit please help !
Have you checked all the Clutch Linkage? Sounds like a Major Break in the Driveline. Good Luck.
NEW Long Forks (A59000)
NEW Long Forks...
296385 (A57192)
296385 (A57192)
JOHN DEERE 750 GRAIN DRILL (A58214)
JOHN DEERE 750...
2017 VOLVO VNL TANDEM AXLE DAY CAB (A58018)
2017 VOLVO VNL...
2022 Horizon Trailer (A55973)
2022 Horizon...
2012 John Deere 624K (A55272)
2012 John Deere...
