1970 Ford 3000 won’t move but goes into gear
   / 1970 Ford 3000 won’t move but goes into gear
Yea I had tried individual braking to try and transfer the torque to the other side to see but that didn’t work , I’m guessing it’s on the input side , I will try and take the shifter cover off today and fire it up and see
   / 1970 Ford 3000 won’t move but goes into gear #12
Many yrs ago my Ford 6700 stopped moving under it's own power while raking hay. The spines on trans input shaft stripped out where input shaft attached to trans. Another possibility is spider gears or associated shaft in differential have failed. One could remove rockshaft housing for a visual inspection.
   / 1970 Ford 3000 won’t move but goes into gear #13
The transmission drive and PTO drives are totally separate in this case. Failure in either one will not affect the other so if the PTO works it proves nothing.
But by the pto working that would atleast tell me the clutch is engaging correct ? Since both disk have to be compressed to work ?
   / 1970 Ford 3000 won’t move but goes into gear #16
No. The PTO is a separate disc. You already replaced the clutch right? I'm "assuming" it's a two stage clutch. They did offer a "transmission PTO" that worked with only a single disc clutch.
Well I came home from work today and split the tractor again , I can do it with my eyes closed now haha and it is a defective brand new clutch , I can move the clutch forks with my hand so I’m not sure if it just jammed or something broke in it , or I read that they need to be adjusted ? Does anyone know those specs or how to do it or if I need to take it off and have someone set it up , the old clutch fingers are sticking out so it will make contact with throw out bearing but after I split it again the new fingers are in and loose so there is no way it is applying pressure on the disk 1st picture is old clutch and second pic is clutch on tractor now
   / 1970 Ford 3000 won’t move but goes into gear #18
My 2000 has the transmission driven PTO, but that second picture of the input shaft sure looks like the splines are all but wiped from the shaft.
It’s just got anti seize on it
   / 1970 Ford 3000 won’t move but goes into gear #20
OK
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
72'' SKID STEER BUCKET (A56857)
72'' SKID STEER...
Pneumatic Grease Can w/Chevron Delo Starplex EP 2 (PARTIALLY USED - AIR HOSE REEL NOT INCLUDED) (A59076)
Pneumatic Grease...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
2016 Husqvarna YTA18542 42in Riding Mower (A56859)
2016 Husqvarna...
