1970 Ford 3000 won’t move but goes into gear
   / 1970 Ford 3000 won’t move but goes into gear
Yea I had tried individual braking to try and transfer the torque to the other side to see but that didn’t work , I’m guessing it’s on the input side , I will try and take the shifter cover off today and fire it up and see
   / 1970 Ford 3000 won’t move but goes into gear #12
Many yrs ago my Ford 6700 stopped moving under it's own power while raking hay. The spines on trans input shaft stripped out where input shaft attached to trans. Another possibility is spider gears or associated shaft in differential have failed. One could remove rockshaft housing for a visual inspection.
   / 1970 Ford 3000 won’t move but goes into gear #13
The transmission drive and PTO drives are totally separate in this case. Failure in either one will not affect the other so if the PTO works it proves nothing.
But by the pto working that would atleast tell me the clutch is engaging correct ? Since both disk have to be compressed to work ?
   / 1970 Ford 3000 won’t move but goes into gear #16
No. The PTO is a separate disc. You already replaced the clutch right? I'm "assuming" it's a two stage clutch. They did offer a "transmission PTO" that worked with only a single disc clutch.
Well I came home from work today and split the tractor again , I can do it with my eyes closed now haha and it is a defective brand new clutch , I can move the clutch forks with my hand so I’m not sure if it just jammed or something broke in it , or I read that they need to be adjusted ? Does anyone know those specs or how to do it or if I need to take it off and have someone set it up , the old clutch fingers are sticking out so it will make contact with throw out bearing but after I split it again the new fingers are in and loose so there is no way it is applying pressure on the disk 1st picture is old clutch and second pic is clutch on tractor now
   / 1970 Ford 3000 won’t move but goes into gear #18
My 2000 has the transmission driven PTO, but that second picture of the input shaft sure looks like the splines are all but wiped from the shaft.
It’s just got anti seize on it
   / 1970 Ford 3000 won’t move but goes into gear #20
OK
JLG 15 MVL MANLIFT (A58216)
JLG 15 MVL MANLIFT...
2019 GALYEAN...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
2018 John Deere 2025R Tractor - 647 Hours (A56435)
2018 John Deere...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
