New attachment... not certain of necessary coupler parts
/ New attachment... not certain of necessary coupler parts #1
ning
Elite Member
Northern California
Branson 3520h
I grabbed one of those front-end hydraulic tree/shrub puller (shrub, in my case, or very small trees) at auction last week.
I have a "third function" diverter set-up on the front loader; as far as I can tell, it's set up with 1/2" ag connections; the grapple I recently bought from WRLong has QCIA8M-8MORB ("1/2" m/f Ag Quick Coupler for 20GPM valve) and it works fine.
The auction attachment came with 3/8" hoses and flat-face connectors, so I need to swap connectors but I'm unsure of exactly what I need.
Here's what was on the end of one of the hoses:
Hose dimension:
Adapter on the right of the coupler pic:
I saw this
Summit Hydraulics 1/2" Ag ISO 5675 Hydraulic Quick Connect Tractor Couplers, Ball Pioneer Style w/Dust Caps, 2 Sets: Amazon.com: Industrial & Scientific
but that's NPT so guessing it won't work.
Will this
1/2" Ag Quick Coupler Set (Q/COUPSET.500-ORB)
"Male & Female: 1/2" Body with 1/2" Female SAE O-Ring Boss Threads"
WRLong wants a ton of money for shipping on that so I'm looking for an alternative.
/ New attachment... not certain of necessary coupler parts #2
The end of the hose has a female M18x1.5 DKOL fitting. The adapter in the 3rd and 4th picture is a male M18x1.5 on one side and male 1/2" BSPP on the other.
If you can find a 1/2" Coupler with 1/2" BSPP thread, it would be a matter of simply swap the flat face coupler with the new one, using the same adapter it already came with.
/ New attachment... not certain of necessary coupler parts #3
The adapter has an o-ring on the coupler side, are you sure it's BSPP?
/ New attachment... not certain of necessary coupler parts #5
Yes. That's what seals against the face of the flat face coupler (in this case) or a port on a cylinder or valve block.
Right, I confused it with BSPT, thanks!
/ New attachment... not certain of necessary coupler parts #8
Every time I buy a kit like that, most of the couplers won’t fit my setup.
Usually by starting at the cylinder and plumb the hoses to fit my stuff that I can get at the local NAPA works best for me.
Hydraulic hoses and fitttings are getting pricey so I try to make every connection as simple as possible.
One of the local parts stores will cut your good hoses and put new fittings on. This really helps to make hoses the same length to connect without that extra loop of hose that gets in the way.
/ New attachment... not certain of necessary coupler parts #9
Surpluscenter.com has a catalog with pictures on types and charts for sizes. Good for reference . I used to buy from them but yesterday I went to a diesel shop with a hyd hose shop. An order of 8 fitting with shipping was $40 at Surplus Center and 3 or 4 days to get. And if they are wrong … more time. At the diesel shop they $21 for 10 fittings in my hand that worked.
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2012 ISUZU NPR FLAT BED  TRUCK WITH PUMP SYSTEM (A59905)
2012 ISUZU NPR...
2015 Jeep Cherokee 4X4 SUV (A59231)
2015 Jeep Cherokee...
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
