What did you buy this week?
   / What did you buy this week? #3,121
This device has worked wonderfully for us in our 40' x 30' detached garage; no more mice. I need to get one more for the new barn we are building.
   / What did you buy this week? #3,122
A Warn VRX 4500 lb winch with synthetic rope for the front of the Kubota RTV-X. At the dealership now for 50-hour service and winch install. Should have it back by Friday.
Back home from the dealer.
   / What did you buy this week? #3,123
Be sure to fab-up a cover of some kind to keep the direct sunlight and rain off your synthetic rope, and reduce the amount of your synthetic lead running from winch spool to your hook.
The synthetic rope is tough and strong, but sunlight is its’ “kryptonite” and will weaken the strands
This is what I did for my 25,000lb Sherpa with synthetic rope. I built a simple cover over the spool with scrap aluminum diamond plate. Note I also have a sleeve over the last 6-8” of rope that remains exposed.
syntet
   / What did you buy this week? #3,124
Bought front and rear Bora 2-inch wheel spacers for the little CK2620. Excellent customer service.
They'll come in handy next time I'm cleaning out a 2-foot wide ditch that is quite a bit wider than it's supposed to be. Then at least only about half of the rears will be suspended by air.
   / What did you buy this week? #3,126
I got Bro-Tek 1.3" on my front, and 3" on the backs, it does help a lot in straddling a ditch, even if you gotta lay the bucket down to keep the fronts out ...
I got 1.25" from BORA for my pickup for chain clearance, both are excellent quality, and service!
I also run chains front and back on my tractor, helps with that too ...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2013 Ford E-350 Cargo Van (A56858)
2013 Ford E-350...
2017 VOLVO VNL TANDEM AXLE SLEEPER (A58017)
2017 VOLVO VNL...
