Cylinder Seal Kits for Kubota Backhoe BH75
/ Cylinder Seal Kits for Kubota Backhoe BH75 #1
Mike-Kubota
Kubota L2800
I need to replace cylinder seals on my BH75. The prices for these seal kits from Kubota are very high, as I am sure that many of you already know...
I am looking to find a source to purchase the seal kits at a reasonable price... I last replaced the seals in one of the swing arm cylinders and the other side blew out soon after... I figure that I will need to replace all of the seals in all of the cylinders (boom, dipper, bucket, and stabilizers) in short order...
I would really like to avoid paying the Kubota prices... Does anyone have any suggestions for a source?
Apparently BH75 was not a popular model as it is hard to find much for it... BH70 and BH77 kits are not compatible as far as I can see...
Thanks in advance,
Mike
Kosse, TX
/ Cylinder Seal Kits for Kubota Backhoe BH75 #2
Hydraulic shop. That's where you go to get seals. Either take the old ones and have them match those or take the entire cylinder and have them do it.
For just the seals, I wouldn't expect much above $40/$50 and that's on the high side.
Thanks for the reply ptsg. Pricing in hydraulic shops around here isn't very good. As an example, I needed to replace the seals on the bucket and boom cylinders on my LA463 recently. Price for seal kit at Kubota was around $145 per kit... best price I could find at hydraulic shop was $120 per cylinder (and that was to just match up seals from an existing one, not to do the replacement...)... I lucked out and was able to find seal kits for my LA463 Front Loader on Amazon for $17.00 / kit. I have no problem with doing the replacement myself, just don't want to pay through the nose for the seal kits.
When I purchased the seal kit from Kubota for one of the BH75 swing arms, it was around $220. Right now, the same kit is listed at $309!
I think that the hydraulic shops (at least around here) have figured out what the dealers are charging, and are pricing just a bit below...
If you can measure and identify all the seals, maybe ordering from Hercules is an option. Hercules Sealing Products
They do have some kits available, but only for the BH70 and BH77. Nothing for the BH75.
Thanks again. Yes, I had been poking around the Hercules site recently. I just submitted a request to them on one of the pages. I figured that I would give it a try, but I don't know if they want to mess around with a "one off" for some random guy with an odd backhoe.... we'll see...
/ Cylinder Seal Kits for Kubota Backhoe BH75 #6
Last Kubota hoe I did was on an old B20 (BT750), and Kubota wanted $200 for just one cylinder. Got all I needed by size out of the Hercules catalog. Less than $90/cyl for what I needed. Prices there are up, too.
Thanks for the reply, dfkrug. I think that I will try to work through the Hercules catalog, see what I can figure out...
/ Cylinder Seal Kits for Kubota Backhoe BH75 #8
Maybe this catalog from Hercules will you help a bit more. Basically shows the various seals available and a cross section of it, which should help identifying them.
/ Cylinder Seal Kits for Kubota Backhoe BH75 #9
dfkrug - I am very much a novice at cylinder repair -- am able to replace the seals if I have a seal kit in front of me. Trying to find the individual seals in a catalog like Hercules seems very challenging to me at this point. Here is a photo of the BH75 Swing cylinder seal kit:
On BH75 Swing, rod diameter = 25mm and cylinder bore = 50 mm.
Can you give me some guidance on what each of these seals are called?
(Head seal, Rod Useal, Piston seal, Rod wiper, o-rings, etc.)
I know that this is a lot to ask of a 'stranger on an Internet forum' but if you have the time I really would appreciate any guidance you can provide... (I really need to get this backhoe functional and can not afford the Kubota prices for seals!)
Thanks in advance!
Is there a link to what you are mentioning here, ptsg? (I am not seeing one, but may not know where to look!)
/ Cylinder Seal Kits for Kubota Backhoe BH75 #13
/ Cylinder Seal Kits for Kubota Backhoe BH75 #14
First, you have to get vernier calipers so you can take precise measurements. I have mechanical ones for both metric and inch scales, but you can get a cheap electric one that does both. Your hoe cyls will be metric, most likely.
Removing and measuring your seals is the next step. Note the shapes and configuration. As a minimum, you need to replace the rod-wiper, the rod seal inside the gland, and the main piston seal(s). You usually do not need to replace the rub-rings or the O-rings not subject to any wear, but do so if they are in a packaged kit or look questionable.
I like to measure the slots where the seals go, rather than the seals themselves. Sometimes there are backing ring(s) that make up 2 or 3 parts of a single seal. You will probably need a U-cup seal for the gland, and a sliding seal for the piston.
I know it seems daunting the first time, but I figured it out without help, and before there were any online videos to watch.
There is a Special Tool you should get to put in the gland seal, but it is not expensive.
There are many many Utube vids now to give you guidance. Here is an engineer's perspective on how the seals work if you want to go a little deeper:
/ Cylinder Seal Kits for Kubota Backhoe BH75 #15
The video I linked above is not linkable, so search for "Mastering Hydraulic Cylinder Seals" on Utube if you want to see an engineer's perspective. I like how it explains the different shapes of seals and how they work, with CAD drawings.
Not everyone's cup of tea, but hey, once an engineer, always an engineer.
/ Cylinder Seal Kits for Kubota Backhoe BH75 #16
Here's the listing of the Kubota PN's for your BH which you may already have but send this to eparts and see what they have
Part #7K501-13300 KIT SEAL Swing 2
Part # 7K501-22300
Part # 7K501-32310
KIT, SEAL (55X30
Part # 7K501-43300
KIT SEAL (60X30)
Part # 7K501-52300
-KIT SEAL Stablizer 2
/ Cylinder Seal Kits for Kubota Backhoe BH75 #17
Thanks for the detailed reply, dfkrug... I need to get a new electronic caliper as my old one no longer works. I will be watching that video very soon... I feel like I have been operating like a trained chimp, in that I go through the motions of replacing the seals and putting the cylinder back together (and thankfully they all have worked!) but I have no idea as to what the various seals are doing... I am very interested in learning more to progress past the trained chimp stage... thanks again!
Part # 7K501-22300
Part # 7K501-32310
KIT, SEAL (55X30
Part # 7K501-43300
KIT SEAL (60X30)
Part # 7K501-52300
Yes, I have sent them to Roger, awaiting his reply... I told him that I would buy all that he can put together, as I will eventually need them all...
2013 International DuraStar 4300 Ledwell 2,000 Gallon Water Truck (A61573)
2013 International...
2011 Dodge Ram 1500 Crew Cab Pickup Truck (A61573)
2011 Dodge Ram...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
Ford F-450 (A63689)
Ford F-450 (A63689)
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
