Hydraulic Upgrades
/ Hydraulic Upgrades #1
Logan11350
John Deere 5400
Hello All,
I have a 1994 John Deere 5400 with the 540 loader. Originally the loader would run off the remotes. I am curious if anyone has advice for adding a block for quick disconnect of the loader but also to hardwire the loader and leave the remotes free for implements. I also often use a grapple bucket and would like a dedicated attachment for loader attachments as well. Does anyone have experience or advice for upgrading the OEM setup with aftermarket valves and joysticks? Any good quality recommendations? I am looking at WR Long.
/ Hydraulic Upgrades #2
Always lots of ideas on that sort of thing, and many will be along shortly. Personally, I'm not a fan of solenoid valves of any type (for various reasons) and rarely go that route. Oddly enough, I'm currently looking at a 5400 with a loader supplied from two remotes. The subject came up about changing that to a dedicated joystick loader valve to free up the remotes. I've looked it over and have come up with a few ideas in that direction but haven't actually started on it yet.
/ Hydraulic Upgrades #3
Just curious, is this setup what you need?
/ Hydraulic Upgrades #4
I don't know how your tractor is set up; I have an older (1985) Italian tractor with a modest hydraulic system that I upgraded a lot.
To run the front loader and more, I added a 3-circuit valve block by diverting the flow pipe between the pump and the factory auxiliary block behind the seat.
This works really well.
The drain-to-tank port just runs from the new valve block to the pressure inlet of the old one, and from there it goes to the 3-point lift.
I also replaced the pump with a larger flow one, and added a priority flow valve to reduce back pressure through the restrictive factory valves (which weren't even adequate for the stock pump).
All this didn't cost a lot; a few hundred bucks for the parts. I made some adaptors and fittings myself.
/ Hydraulic Upgrades #5
Hello All,
Hello All,
/ Hydraulic Upgrades #6
I have an old Farmall 300. It has 3 levers for hydraulics. 1 Works the drawbar, 1 works the loader, and the last one works the loader bucket. I added remotes to the rear of the tractor by putting tees and valves in the lines going to the loader bucket. When I want my remotes I just shut the valve going to the bucket. the bucket will stay level while using the remotes. A simple job but it works very well. hope this gives you some ideas.
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
LIGHT PLANT GENERAC MAGNUM (NONE TITLED) (A63569)
LIGHT PLANT...
2015 JAYCO JAYFEATHER TRAVEL TRAILER (A63569)
2015 JAYCO...
Rhino 12ft Blade (A63688)
Rhino 12ft Blade...
2022 EZ-GO ELITE...
1999 JOHN DEERE 344H WHEEL LOADER (A63276)
1999 JOHN DEERE...
