SA425 Block Heater Kit #119E21-95010 - Installation
/ SA425 Block Heater Kit #119E21-95010 - Installation #1
LogCabinRanch
Yanmar SA 425
I went on installing the OEM Yanmar Block Heater Kit #119E21-95010 but I could not get the plug out using a screwdriver. Instructions call for hitting the inner edge, but the plug is smooth, there is no inner edge that I could see. Did anyone installed this, and if so what was the trick to get this plug out? Thank you for any suggestion.
/ SA425 Block Heater Kit #119E21-95010 - Installation #2
There are ways to get the plug loose. Plenty of YT vids on the topic.
Attached is the generic Yanmar block heater types and helpful instructions.
  • YANMAR BLOCK HEATER INFO.pdf
/ SA425 Block Heater Kit #119E21-95010 - Installation #3
Try pounding on the furthest from center to rotate the plug. The last freeze plug I removed I had to punch a hole near the edge, then pry it out.
Thank you! I was tempted to drill a hole in it, and pry it out that way, but this is definitely cleaner approach. I am hoping that I will not push the plug too far inside while doing it...
/ SA425 Block Heater Kit #119E21-95010 - Installation #5
I would NOT drill it. You're practically guaranteed to get shavings in the coolant passages. The plug will eventually rotate... You couldn't push it through the holes unless you really tried.
/ SA425 Block Heater Kit #119E21-95010 - Installation #6
I recently found out one of my wranglers had a block heater installed as a dealer option. Completely useless item on a California car. I discovered it when it blew out on the highway and purged the coolant. Needless to say I have a nice new freeze plug in its place now.
/ SA425 Block Heater Kit #119E21-95010 - Installation #7
If you haven't already removed it, I've always used a punch to knock one side of it inwards towards the block. Then you can get vice-grips on the edge that is sticking outwards and pop it out.
2006 Ford Crown Victoria Sedan (A59231)
2006 Ford Crown...
2014 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59908)
2014 FREIGHTLINER...
Giyi SE61 QA Broom Sweeper (A60463)
Giyi SE61 QA Broom...
John Deere 6110M (A53317)
John Deere 6110M...
TANK MANIFOLD (A58214)
2014 FREIGHTLINER CASCADIA (A60736)
