MUST READ! Mahindra CRD Full Diagnostic Manual with Check Engine Codes
   / MUST READ! Mahindra CRD Full Diagnostic Manual with Check Engine Codes #61
Well same problem happened to me again 3 years later at 722 hours in my tractor. Curious if anyone has gotten their hands on the FES Diagnostic Tester V17.0 software? If not, off to the dealership, I go to get the Kos reset again.
I have been in communication with another fella about backing up my ECU once I get back from the dealership. He is suggesting using https://www.amazon.com/SM2-PRO-US-Standard-dongles/dp/B0FH4C37XD
If anyone has any other comments or questions, please contact me via: robinsonpowerstroke@gmail.com
   / MUST READ! Mahindra CRD Full Diagnostic Manual with Check Engine Codes #62
I just stumbled across this link to a 361 page pdf for the Mahindra CRD Diagnostic Manual (Arjun Novo, Mahindra sub company)
http://kisandost.com/KisanMitraWeb/MarketBulletinView?moduleType=SubjectPartFile&FileName=203
I've only quickly browsed it but this appears to the mother of all Jackpots for Mahindra Owners.
Page 68 of the PDF starts the Diagnostic Code Manual
And will list all diagnostic codes.
The PDF is interactive, so you can click a topic and it will take you to that page, you can search, etc.
It tells you how to trouble shoot the error, what the causes are, etc.
Everyone should save this to their desktop immediately to have a hard copy.
It may not be your specific tractor, but i'm sure these codes are relatively universal.
Moderator should probably make this a sticky too if that's possible here.
Seriously this is what every single person has every asked for that has come here with problems.
I simply Googled what Jabonee reported in my thread for my check engine light "P1804 RAIL PRESSURE LIMITER OPEN" and this was the 4th link down with a full successful match.
I'm in shock....
This is legitimately a factory service technician manual with every single step...
-Haas
***edit with addition:if anyone is unfamiliar; you can look up almost all of the mechanical diagrams for your Mahindra tractor & attachments on the Mahindra USA site under the Parts Catalog. Those diagrams, along with this manual should allow you to cover a large majority of what's going on in your tractor (if it's similar to the larger tractors like the one listed in this manual)
here's the link to the mahindra site parts catalog
Object reference not set to an instance of an object.
I'm in shock....
-Haas
I have the same exact issue. I have a p1804 pressure rail code set. The link for this Garuda code cheat sheet no longer works. Is it possible for you to email me a copy that you had saved? I would be forever grateful. If not, can you tell me what the P 1804 code cross referenced to? And if it led you to a fix. Thank you.
   / MUST READ! Mahindra CRD Full Diagnostic Manual with Check Engine Codes #63
I need you to
s
I need you too send me your email address so I can share the complete diagnostics manual, the file is large.
   / MUST READ! Mahindra CRD Full Diagnostic Manual with Check Engine Codes #64
Did anyone save a copy of the manual mentioned early in this post? It's no longer available online. I'd be super grateful if someone has a copy they could email to me. Let me know. I'm stuck 3 hrs from a dealer and my tractor is running bad.
   / MUST READ! Mahindra CRD Full Diagnostic Manual with Check Engine Codes #65
That is the diagnostic manual I would like to email to you. Unfortunately all the 1800 codes you will need to go to the dealer to get cleared. You need the FES Diagnostic Tester V17.0 software in order to clear all the 1800 codes.
CFG Industrail MX15RX (A53317)
CFG Industrail...
1998 6X12 Utility Trailer (A56859)
1998 6X12 Utility...
2006 Volkswagen Jetta Sedan (A55758)
2006 Volkswagen...
2018 John Deere 4066R (A53314)
2018 John Deere...
2012 Chevrolet Silverado 3500 HD Enclosed Knapheide Service Truck (A55973)
2012 Chevrolet...
2012 DODGE RAM 1500 CREW CAB PICKUP TRUCK (A57880)
2012 DODGE RAM...
