Light Problem on 5155
/ Light Problem on 5155 #1
bsekf
Gold Member
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
Bought an almost new Mahindra 5155, it had set outdoors at the dealers last winter. Had some, after market, LED light installed. Tractor works great, but no lights except the ones with independent switches(4 ways and work light and LED's). I have checked the fuses, they are mini's and difficult to remove and check, all appear good. The $300 4 way light switch, turn signal, horn and high/low beam headlights, may well be the problem, but changing it is a last resort. There are relays in the fuse block for high beam lights, low beam lights. How do you check those relays?
Any other ideas?
/ Light Problem on 5155 #2
Any other ideas?
Ruebicon Aftermarket Mahindra parts has the light switch for less than $100.00
I went to their site and didn't find a light switch for the 5155. Can you send me a link?
/ Light Problem on 5155 #4
I believe I'd start with whomever installed your after market lighting. If the normal lights worked before that modification perhaps they could shed some light on your issue.
The after market lights work with the work light switch. Itis only the factory lights that run through the 4 way light switch that don't work. The first owner who installed the LED lights says all the lights worked when he traded the tractor in. I have got to check the fuse block again, but I fear it is the switch.
(6) Finger Pickup Meters (A65640)
(6) Finger Pickup...
Log Chain (A65640)
Log Chain (A65640)
2004 Mack CH613 Concrete/ Water Mixer Truck (A64194)
2004 Mack CH613...
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
case 370 glass door never installed (A61307)
case 370 glass...
2003 Keystone Cougar Model 286 Camper / 5th Wheel (A66285)
2003 Keystone...
