how do i turn the fuel up on a yanmar ym 146
   / how do i turn the fuel up on a yanmar ym 146 #1
1971bmw2002
ym146
i've been wondering how to get more power out and maybe make some cool smoke and was wondering if any of yall know how to turn the fuel pump up or if there is a governor I need to adjust or whatnot. thanks in advanced!
   / how do i turn the fuel up on a yanmar ym 146 #2
No there's not. Bigger Cyl. and Pistons about it. BTW. That's how the Org. yanmar roll over happened. Killed a kid! Linkage stuck Wide _ss open trying to get more power. Good luck and hope you don't get anyone else killed!!
so theres no way to turn the fuel pump up?
   / how do i turn the fuel up on a yanmar ym 146 #4
How much financial and health risk are you willing to take ? Being able to roll coal is a terrible reason to want to do that. Out of curiosity, how old are you ?
It’s not
It’s not gonna kill me lol I’m just looking for a little more grunt out of it
   / how do i turn the fuel up on a yanmar ym 146 #8
More grunt would be to add wheel weights, increase traction. Messing with the fuel on a diesel is a good way to have it come apart. Can you afford to replace the engine?
The best way to get more grunt (work!) out of a diesel is to let it work longer, not faster. Slow and steady for long term is a lot better than a quarter mile run before the engine blows.
Patience is a vitue...
David from jax
   / how do i turn the fuel up on a yanmar ym 146 #9
I honestly doubt those little 2 cylinders would stand much more fuel. You blow that motor up you're screwed. Parts will be hard to find. But if you have a boat and need an anchor you're in luck.
   / how do i turn the fuel up on a yanmar ym 146 #10
It’s not
To get more grunt out of the machine is to swap the DIFF gears and up the tire sizes.
Basically, a YM146 is a GT Garden Tractor. It's not a racer. Although there is a YM3000R racer out there.
The YM3000R, you'll need a racing helmet like robin has here,
2016 Peterbilt 567 Wet Kit Tri-Axle Day Cab Truck Tractor (A55852)
2016 Peterbilt 567...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2013 Ford Taurus (A56859)
2013 Ford Taurus...
fire truck 2007 (A56858)
fire truck 2007...
Pivot End Guns (A56469)
Pivot End Guns...
Brown 684 3pt 7' Tree Cutter (A56469)
Brown 684 3pt 7'...
