Mahindra
/ Mahindra #1
adam46
ford 3000
Have a 2012 4250 mahindra and the safety switch attached to the gear shifts is not allowing me to start the tractor. I have replaced the switch once and it is stopped working again. Any ideas?
/ Mahindra #2
Could we assume a fault in the original switch and the replacement also? I’m sure it’s not any physical damage you can see. Good luck Sir
/ Mahindra
I can try and replace again and maybe that will work
/ Mahindra #4
You have actually tested the switch (and related circuits) and know it's bad, or just assumed so because of the "no start"? If it's just a bad switch I know what I would do, but it's probably not politically correct to suggest it.
/ Mahindra #5
I had this happen in my 2018 last year, I replaced it and it was right as rain. Fingers crossed you get it figured out soon.
/ Mahindra #6
I'll say it. I'd just bypass that switch. Proceed at your own risk.
2017 Ford Explorer 4x4 (A62679)
2017 Ford Explorer...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
2017 Ford Box Truck (A62613)
2017 Ford Box...
Case 1845C Uni-Loader Skid Steer (A62679)
Case 1845C...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
Metal Hog Feeder (A65640)
Metal Hog Feeder...
