Where do you park/store your tractor?
/ Where do you park/store your tractor? #41
In the first pic that's where the (I bought new) 1978 B7100DT spends the winter, in the summer that's where the 2012 L3540HST with FEL and BH sits.
In the winter the L3540HST is in the shop, heated only when I do snow clean up.
/ Where do you park/store your tractor? #42
My 2004 Kubota L5030hstc has been stored in a car port with dirt floor. No rust what so ever.
/ Where do you park/store your tractor? #43
It probably varies lot by region. Around here, any garage or barn without a concrete floor is wet inside, especially in springtime. I've seen some so bad that the joist hangers under the rafters have rusted away, from the moisture coming up out of the ground and trapped against the underside of the roof.
I stored one of my trailers for a year or two in one such garage, and eventually concluded it was better off outdoors, in our climate! :ROFLMAO:
/ Where do you park/store your tractor? #44
all my equipment sits in a gravelled floor pole barn. Sliding doors in front and open windows in back. No rust even on the older equipment or the newer powder coated stuff.
How close are you to the Bay Fundy / Ocean??
I always wondered how much more rust stuff near the oceans get??
I lived most of my life on the coast, in Richmond B.C., a suburb of Vancouver. My experience is that my travel trailer winters better, here in the centre of the province, with just sitting untouched, than It did there with a little heat, water absorbing crystals, and opening windows every few days when there was no rain.
/ Where do you park/store your tractor? #46
In a decrepit, dirt floor barn….but it’s the best I can do.
/ Where do you park/store your tractor? #47
Id wager, a dirt floor barn on a proper grade, would be fairly dry.
/ Where do you park/store your tractor? #48
Here in Nevada the sun is the big destroyer, not rust. According to the National Weather Service so far this calendar year we've received just over 3" of precipitation. Most times the humidity hovers around the single digits. I put up a 100' x 30' pole barn, just a dirt floor, to protect my "stuff" from the sun. It is open to the north as all of our major storms (mostly wind) come from the south. Everything with tires, including trailers, is parked in the pole barn out of the sun's reach.
/ Where do you park/store your tractor? #49
The contractor that did my pad, has a pole barn that came with the house he bought and the grade is wrong. The frost cracked the concrete bad and is tearing the barn apart in one place.
In fact when the PB company did my barn I told the foreman that the ribbon on that stake is the grade. I came back later when they were putting up the greenboard and I asked them about the grade stake. They said they didn't use it, so I told them to tear the greenboard down and do it over, which they did.
That foreman did other things wrong, I just bit my tongue and said to myself anything they screw up they will fix. If my older brother was the owner, he would have been on the phone with corporate screaming.
Since everyone is posting their tractor home, here is mine. It is open on all 4 sides so plenty of ventilation but in bad storms the rain and snow will blow in. Not the best setup. The 2nd and 3rd pictures shows my garage which is not big enough to hold all the toys/tools plus tractor, so the tractor only comes in for maintenance.
/ Where do you park/store your tractor? #55
Mine spent the first 9 years in my garage in my basement but it was getting too crowded. I finally bought a 14' x 24' storage shed just for the tractor and tractor stuff. It's just a treated plywood floor. I plan to throw down some stall mats to keep the tire chains from chewing it up in the winter. No electricity or heat but otherwise it's great so far.
/ Where do you park/store your tractor? #56
Yesterday I bought stall mats to cover my dirt floor but then I thought "what happens if my tires freeze onto the mats?" Oh well, I guess I will find out.
/ Where do you park/store your tractor? #58
Something rigid on top of the mats (scrap of plywood?) would prevent them from "following" the tires out, if frozen.
Good idea! I was already planning on having 2x4 scraps under the blower and plow blade.
John Deere 8400 Tractor w/ Duals (A64047)
John Deere 8400...
Kubota Z232 (A60462)
StarFire 3000 Receiver (A63116)
StarFire 3000...
2013 Infiniti JX35 AWD SUV (A61574)
2013 Infiniti JX35...
ATS ME18 Mini Excavator (A64047)
ATS ME18 Mini...
Rhino Servis 2160 Ditch Bank Mower (A62180)
Rhino Servis 2160...
