Backup camera for tractor
/ Backup camera for tractor #21
I got a pair of 1080p with split screen if you want it for about 120 bucks. I used velcro and zip tied the front camera to the crash guard and it helps with implement changes. The rear one is nice for snow blowing I had to make a rack to hold it up, did not want to drill the plastic cab hood. It saves me from having to turn around and look all the time, just do that in the tight spaces. The backup I could live without but the front one is staying.
/ Backup camera for tractor #22
I've found that it's difficult to mount one or even two cameras on a tractor that will show what you need for all types of work. Powering the cameras is also tricky if you want to avoid running wires. Solar is an option but not for heavily shaded areas or at night. I solved these problems by making my own portable camera system.
I took my existing 2 camera wireless system and modified it to use cordless tool batteries. I added strong magnets so the cameras and monitor could be placed almost anywhere. It's sometimes better to put the camera on or near the work, rather than on the tractor.
View attachment 4182918 View attachment 4182919
View attachment 4182920 View attachment 4182921
View attachment 4182922 View attachment 4182923
View attachment 4182924 View attachment 4182925
View attachment 4182926 View attachment 4182927
This idea will work for most camera systems using an adapter for the brand of cordless tool batteries you use.
I don't always need the cameras, so the magnetic mounts are temporary. Most of the time, the system is in a case behind the tractor seat and deployed when necessary.
View attachment 4182928 View attachment 4182929
I like the use of tool batteries. I only need my camera for when I'm running the stump grinder. Off to amazon...
/ Backup camera for tractor #23
I just use a mirror
Same here. Got one that I made a magnetic mount for and put it on the FEL frame. Easy enough to take off when I don't need it, or if it'll get in the way. Only issues is vibration makes it hard to see very well with it.
Open station here too, not sure where I'd mount a screen where it would be out of harm's way.
/ Backup camera for tractor #25
I have 2 one back-up permanent mounted and one temporary mounted with magnets.
/ Backup camera for tractor #26
There are camera systems with built in rechargeable batteries but it's been my experience that they are usually dead or low on charge when I need the camera. I always have a supply of fully charged cordless tool batteries on the shelf, so it makes sense.
I use these handy tool battery adapters for powering a variety of projects. Be aware though that with some brands, the low voltage cutoff is in the tool, not in the battery. It is possible to over discharge using these adapters, which may damage the battery. Best to check the brand you use to be sure.
I particularly like the Milwaukee M12 batteries for their compact size.
I use them for powering smaller tools, like this hand held fuel transfer pump:
Unfortunately, Milwaukee, along with DeWalt, are among the brands that don't have a low voltage cutoff in the battery.
/ Backup camera for tractor #27
View attachment 4327167 View attachment 4327168
Excellent info, thank you.
Sounds like my Makita batteries likely have a cutoff in the battery if they're newer. But apparently my Ryobi's all have it which is awesome because they're my throw away tools.
/ Backup camera for tractor #28
I really like this setup and good information about the low voltage cutoff. I had no idea about this.
/ Backup camera for tractor #29
For a few of my cordless tool battery projects, especially those that run unattended, I use these low voltage cutoff circuit boards:
They're cheap, compact, easy to wire, and work with voltages from 5V to 60V.
/ Backup camera for tractor #30
I bought a <$50 Amazon wired back up camera. Mounted the camera and screen with magnets so I can move them around. I made a shade for the screen from a 2 gallon plastic black oil can. I wanted something to watch my mounted equipment. Works and I can move both units around. In bright sun the picture fades.
2022 LINCOLN  VANTAGE 549X (A63569)
2022 LINCOLN...
2013 PETERBILT 367 WINCH TRUCK (A63569)
2013 PETERBILT 367...
DEUTZ ENGINE (A63569)
2015 KENWORTH T880 STAND UP SLEEPER (A63569)
2015 KENWORTH T880...
LILLISTON 8R ROLLING CULTIVATOR (A63291)
LILLISTON 8R...
2011 JACK  130BBL (A63569)
2011 JACK 130BBL...
