What is this, and what can I do with it?
   / What is this, and what can I do with it? #1
Yamezz
South Australia
JD 3720 cab, JD X495, JD L100, JD D105
When I bought my 2012 JD3720 second hand in 2016, the dealer gave me a bunch of parts that I think he said were a safety system to prevent the loader from tipping out the front or over the back when the loader is raised. Not a self-levelling loader, but some kind of safety to prevent accidents. Either way, it was not fitted to the tractor, and I never did anything with it - just put it on a shelf in the back of the shed. Now, while cleaning up, I've come across it again. The rats have had a chew on these hydraulic bits, but I presume they're electrically-operated hydraulic solenoid valves. If so, what cool projects could I use them for?
   / What is this, and what can I do with it? #2
I thought it was a multiplier, but can't see where it would get input from.
David from jax
David from jax
There are two fittings on the top of the last picture. There's a rat-chewed plastic protector on each. Sorry, I didn't realise I didn't photograph that part until now.
   / What is this, and what can I do with it? #4
This is part of the anti spill system. This was feature for the AU market. I don't think the US loaders came with it.
Basically, as you raise the loader, it won't let you drop whatever it's in the bucket, on top of you and the tractor. It uses a set of cams and linkages on the loader that actuate a limit switch that then turns those solenoids on or off to stop the loader from moving.
And the page from the parts catalogue: https://partscatalog.deere.com/jdrc/sidebyside/equipment/299/referrer/navigation/pgId/2563808
   / What is this, and what can I do with it? #5
I knew someone smarter than me would figure this out!
David from jax
Yes, that's it.
I don't want to install the anti spill system, so what else could I use these components for? Third function on the loader, maybe?
   / What is this, and what can I do with it? #7
Yes, that's it.
It's only an On/Off valve. Think of it as a ball valve for a garden hose.
Can't really work as a third function.
   / What is this, and what can I do with it? #8
It's green so it probably cost at least $1000. I'd part with it in a minute. The "function" seems like it would be more frustrating than usefull.
   / What is this, and what can I do with it? #9
Why are there two solenoids? Wouldn't just one in-line do it on the return or is there bleed through the pressure?
   / What is this, and what can I do with it? #10
One is for the lift and the other is for the curl. It locks both functions once it trips the limit switches.
2017 Ford F-250 Enclosed Service Truck (A53422)
2017 Ford F-250...
Kawasaki NR (A50324)
2005 Ford F-250 Service Truck (A55852)
2005 Ford F-250...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A55851)
2025 HT360W Mini...
2014 John Deere 204K Wheel Loader (A53485)
2014 John Deere...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
