Bad diesel exhaust fluid?
   / Bad diesel exhaust fluid? #1
w7dms
Sandy, Ore.
MF1531
does def go bad, if so how do you tell that it is bad. then what do you do with it?
   / Bad diesel exhaust fluid? #2
Yes, diesel exhaust fluid (DEF) can go bad if it becomes contaminated or if it is stored improperly. It is recommended to use DEF within one year of purchase and to keep it in a cool, dry place away from direct sunlight to maintain its effectiveness.
Probably by the production date. If it’s more than a year, don’t use it. If the jug has been sitting open long term, don’t use it. If sitting outside in the sun, don’t use it.
   / Bad diesel exhaust fluid? #4
If you buy jugs, ALWAYS make sure the seal is intact before opening. Years ago there were reports of WalMart jugs refilled with water.
thanks to all for your help. i bought a 250 gal tote with about 100 gallons of def; at an auction. but it had a pump system on it that i wanted, so i made out ok.
   / Bad diesel exhaust fluid? #6
30007 (A53424)
30007 (A53424)
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
2005 IC Corporation PB105 School Bus (A54814)
2005 IC...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
2024 John Deere 8R 410 MFWD Tractor (A53485)
2024 John Deere 8R...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
