Nobody ever talks about just washing their tractor. Do you?
   / Nobody ever talks about just washing their tractor. Do you? #21
When Logging, first in the mud and then in droughty dust conditions, the M gets mightily dirty and the cab gets filled with wood chips and sawdust from me climbing in and out. So when there’s a break in the action, too rainy or otherwise, I do vacuum inside the cab and spray down the exterior. The rest of the time when not logging, I don’t bother.
   / Nobody ever talks about just washing their tractor. Do you? #22
I gave it a wash and wax when it was used in a wedding.
   / Nobody ever talks about just washing their tractor. Do you? #23
God put the dirt on and God can wash it off when it rains.
   / Nobody ever talks about just washing their tractor. Do you? #24
Dang, does it work?
This is a long time thing: is it a lawn 'tractor' or is it a real tractor?
If a lawn mower, clean it.
Most bigger tractors could give a ****. But if you re smart you will grease everything. Done,
   / Nobody ever talks about just washing their tractor. Do you? #25
I mostly want to spray the cab floor and clean the windows by hand. But then I need to hit the pins and I stay away from boots. Why? So I can see new grease. Then I actuate EVERYTHING and short grease it again. If you've never done pins and bushings then grease is really cheap.
If you've never banged apart gouged, scored and ruined pins and bushings for lack of a squirt you have not lived. They don't come part without crazy force. Then they have to be rebuilt.
It's probably not a problem on your lawn mower.
   / Nobody ever talks about just washing their tractor. Do you? #26
My old man taught me to check all the fluid levels and grease all the fittings every time I use the machine. I hated doing it.
   / Nobody ever talks about just washing their tractor. Do you? #27
The crop I grow demands numerous corrosive sprays during growing season, an airblast sprayer saturates everything.
If I want my equipment to work properly, it is best to keep them clean and serviced
Washed about every two weeks, waxed at the end of each crop year. Some day I may want to sell a tractor or equipment, appearance matters to a prospective buyer
   / Nobody ever talks about just washing their tractor. Do you? #28
I'm probably not as dilligent about greasing as I should be, but I try to do it either before or after extended loader use.
   / Nobody ever talks about just washing their tractor. Do you? #29
Mine gets a bath a time or two a year. When I do my oil and filter changes, I wash it and grease it.
   / Nobody ever talks about just washing their tractor. Do you? #30
Wash, vs spray off? I spray mine off every few months, but "wash" no.
I do the same. Hit it with a garden hose when it’s really dirty. Otherwise just use a leaf blower to blow off the dust and chaff.
4 Unused Montreal ST205/75R15 Trailer Tires (A53421)
4 Unused Montreal...
DYNAPAC CC950 SMOOTH DBL DRUM ROLLER (A52707)
DYNAPAC CC950...
2019 Bobcat 3400 4x4 Utility Cart (A55851)
2019 Bobcat 3400...
23018 (A55758)
23018 (A55758)
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
