What is some of your Pet Peeve's
   / What is some of your Pet Peeve's #2,461
I am very close to having a new peeve. Need to verify this first, but the other day, I could SWEAR I saw a new police cruiser with a "dazzle" paint scheme, just like the ones they put on Navy ships during the war to make them hard to see. I just caught it out of the corner of my eye passing me the other direction, but I'm almost sure that's what is was. No excuse for deliberately making emergency vehicles hard to see.
Has anyone else seen one of these? I would post a pic, but I can't even find one on the internet (probably because it's such a bad idea, no one else has done it).
Not sure what you mean by "dazzle paint scheme", but I've noticed several of the towns around here have the lettering on their police cars only a couple shades different than the vehicle color itself (in this case, black, with dark gray lettering). Mostly Ford Explorers, so they blend right in with all the other midsize SUVs. I'm sure it was deliberate, but not sure why, stealth maybe?
I'm sure this has been posted, but doing it anyway: Brick and Mortar stores that don't have anything. Wall clock in the shop died, looking at Blowe's and Home Creepo, 1200 clocks in the warehouse, not a single one in any store. Have to order it and wait 4 days.
Wouldn't have thought to look for a clock at Lowes or HD. Walmart seems to have a good selection.
   / What is some of your Pet Peeve's #2,462
The thoughts that bounce around in one's head late at night are funny and unpredictable, but this bag thing came back to me, and here's what I was thinking: single-use plastic bags nearly always blow out on the bottom, when something sharp in the bag starts a tear. It's never the handles that fail, and any tear that starts higher up usually still holds the item, not a catastrophic failure.
So, if "they" really wanted to save plastic, rather than making the bags so thin that everyone just uses twice as many, they'd do well to make the bags a gradient thickness. Go ahead and make the top half and handles of the bag as thin as 0.5 mils, but keep the bottoms at 1 mil. You'd think this'd be easy enough by making them of sheet stock that's thicker on one edge than the other, or thinned down in the middle (they seem to fold and seal to make these). With thicker bottoms, most might only use 1 or put twice as much into each, and you'd be saving net plastic usage with the thinner tops, where strength isn't needed as much.
I looked it up. Bags are "welded" at bottom, 350° which is where they blow out. No the handles never break...they just stretch until it's like carrying a cinder block with piano wire!
   / What is some of your Pet Peeve's #2,463
Ours vary. Yes, some are welded at the bottom, but others are just folded at the bottom with the sole welds at the handle tops. But even those welded at the bottom never seem to split at the seam. Rather, some sharp object usually tears thru the bag either side of the seam, and then it fails.
   / What is some of your Pet Peeve's #2,464
   / What is some of your Pet Peeve's #2,466
I recently ordered a nightstand clock from Amazon. I had to have a bedroom clock that doesn't 'tick' which drives me crazy. It has a blue lighted dial that has a brighness control . Wide open you could read a book so I keep it low as it goes.
I wanted 120vac, analog, no ticking.
Batteries are a pain.
A ticking, battery powered digital bedroom clock would put me in the loony bin!
   / What is some of your Pet Peeve's #2,467
I use my phone as alarm clock, we lose power here too often for AC one
   / What is some of your Pet Peeve's #2,468
I'm the opposite. I enjoy hearing them tick. My father liked old clocks and as we were cleaning the house out I kept one of them wound, so that it would chime every half hour. I thought about bringing one home but out of 4 clocks-including his grandfather clock- only one worked and after reading up on what it takes to keep them going I opted not to. Instead I have a Chinese battery operated clock with a pendulum which I bought at a yard sale.
   / What is some of your Pet Peeve's #2,469
I'm frankly surprised to learn there's anyone under age 80 who doesn't!
I've had one form or another of small charging cradle or stand for my phone on my nightstand since at least 2010... maybe earlier. No need to muck up the room with another usless and annoying appliance, the phone is always with me. :p
   / What is some of your Pet Peeve's #2,470
Growing up my parents collected antique clocks. So a few Grandfather clocks, lots of wall and mantle clocks. Dad would oil & wind then keeping them running. Most had Westminster chimes...every 15 minutes then a chime on the hour...except for the coo-coo clocks which I fantasized strangling those dam birds.
2015 Kubota MX5200F 55HP Loader Utility Tractor (A55851)
2015 Kubota...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2014 BMW 320i Sedan (A55758)
2014 BMW 320i...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
