Typhon Terror XVII with cab.
   / Typhon Terror XVII with cab. #51
Edit 6/29: Well it is worse than I thought. 3 6mm Allen screws and some prying and the plate comes off but the battery is behind welded bars. It seems the left side panel (blue) would also need to come off and to do that it looks like the cab has to be pulled off first. At some point in the future I expect to modify the left side panel so that access to battery would be possible without lifting cab off first. Likely cut off the metal portion next to the fuel sight gauge and maybe hinge it for opening.
Thanks very much MattB4 for posting your experience with this mini ex. I bought the same model about the same time as you but have still used it very little. The battery position is incredibly dumb. I asked Typhon Machinery how to remove the battery and they sent instructions for the open model. When I pointed out that their instructions didn't work for the cab model, they admitted that the cab had to be lifted to remove the side panel to get to the battery. They sent a video link. Hopefully it works on this forum (a Google drive download): 3453_1761635669.mp4.zip
It skips over what to do with the wiring. However, I think the cab only needs to be lifted a few inches to get to the side panel bolts so it may not be necessary to disconnect the wires.
   / Typhon Terror XVII with cab. #52
Pretty amazed that you could even get air condtioning on this size machine and even more amazed it was available at the price you paid.
I was going to ask if that machine had air conditioning.
I have a smaller XI with the gas Briggs & Stratton and the hood gets quite warm.
I can't imagine it being enclosed....except maybe when it is 0° outside......then you may want it.
Looking at the video of how they get at the battery it just confirms my decision to abandon in place if the battery should go bad. I noticed they do not show disconnecting the battery cables in the tight location. A rather glaring omission.
I have run my excavator only ~15 hours so far. I went ahead and changed the oil and filter last month for the engine. My opinion of the excavator is that it could be better. Lots of seemingly poor design decisions. Like for instance the tooth bolts on the bucket are a loose fit in the holes and lack a locking washer or nylon ring bolt. I replaced mine with 1/2 inch by 1-1/2 inch grade 8 bolts.
It runs better than my previous 1-ton Typhon but at more than double the price I would say it does not provide double the value.
2020 Freightliner Derrick Digger Truck (A55973)
2020 Freightliner...
Hyundai HL 960 Wheel Loader (A56857)
Hyundai HL 960...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
Landoll Lowboy Trailer (A55315)
Landoll Lowboy...
2007 FREIGHTLINER M2 26FT BOX TRUCK (A57880)
2007 FREIGHTLINER...
