MattB4
- Joined
 - Aug 4, 2023
- Messages
 - 717
- Tractor
 - Cat 262 skid and Typhon XVII
Drained and replaced the hydraulic fluid. There is a 6mm Allen plug under the tank on the bottom side of excavator. By turning the deck so that this plug sits over the rear center of tracks I could place a 5 gallon bucket underneath to catch the oil. Filling back up with the cab in the way however is near impossible if you intend to pour in oil. My solution was to use a battery powered fuel transfer pump that I had bought off Amazon last week for ~$20. I had bought it to pump diesel into the Excavators fuel tank which it worked great doing.
To see if it could pump hydraulic oil I placed it in the 5 gal bucket of waste oil and turned it on. It works! Though very slow pump rate due to the heavier oil. By using the pump it was about 10 minutes of pump some oil, go check site glass, and pump some more. From the factory they had overfilled the hydraulic oil so for my purpose I only placed back enough to be about 2/3 of sight glass level. Roughly 3 gallons.
I am glad I decide to do this right off the bat and only wished I did not have to do that 1 hour of run time getting the excavator home. The factory oil looked hideous and there was debris in it. Some looked like small pieces of hose rubber.
One other item I found was that the windshield wiper had the splines for the arm stripped so that it would not drive the blade back and forth. Not seeing a great need for it anyway I simply unbolted the arm and removed it.
Doing some operation after the oil change to work all the hydraulic cylinders I also decided to test the machine by pulling 4 7-8ft pines out of the dry ground. No problem and no feeling of about to tip over that my old 1-ton would have with doing that. Do have to watch while in crushed rock that the tracks can bind if you get gravel in them.
