How to attach to house?
/ How to attach to house? #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Several years ago, brother in law came. He added an awning above the garage door. Wife wants to duplicate it on the other side of the house.
Question is.... we can't see how he attached things. He didn't have a nervous breakdown.... but he's crawled into a hole and won't 'talk to the world' so I can't simply ask him.
As I recall, (and we have more) those are 12" long "log screws". Threaded 2-3 inches on the tip, rest is shaft. I can't believe he screwed those into the block itself.... is there any special anchor that you might use? Need any thoughts of epoxy or just tighten them down?
We've got the parts (that you see in the picture) already cut/stained, ready to mount. Already have the crossboards.... so this is essentially ready to go but for not knowing what he used and how he might have done it.
I'm always nervous drilling into blocks. Frankly, I would have rather NOT done it just so I can be 100% sure nothing is going to crack on me. Also, it's split face block. Wife seems to forget we won't be able to get a flat surface unless we take a grinder to it (like was done before). Again, I'm not keen on that but, it's been done and what do you say!!!
This "brow" is only two, maybe two & a half feet deep. It's just to help keep some water from landing closer to the house & splashing up on things. Thankfully, nobody will be walking on it!
/ How to attach to house? #2
Here are some general guidelines for attaching to cinder or concrete block:
For General/Medium Duty (Hollow or Solid Block):
  • Sleeve Anchors: A versatile option that expands along its length, ideal for hollow block, and good for objects under stress.
  • Lag Shield Anchors: A classic choice, with longer versions suited for softer cinder block.
  • Toggle Wing Anchors: Specifically designed for hollow walls, they have wings that expand behind the block for strong holding power.
For Heavy-Duty (Solid Block or High Stress):
  • Wedge Anchors: Provide extreme strength for heavy loads and are best for solid concrete or block.
  • Chemical/Epoxy Anchors: Offer the strongest fixing by embedding a threaded rod in a chemical adhesive, ideal for very heavy machinery or structural attachments.
For Light-Duty:
  • Tapcon Screws: Good for light attachments, but use a smaller masonry bit and consider adding construction adhesive for better grip, especially in hollow cores.
Key Considerations:
  • Hollow vs. Solid: Cinder block has hollow cores, which significantly impacts anchor selection. Toggle wings and double expansion anchors work well in hollow areas.
  • Drilling: Always use a sharp masonry bit and a hammer drill for cinder block.
  • Adhesive: Modern adhesives can significantly improve the holding power of any fastener and help even out inconsistencies in the block.
  • Material Hardness: For very hard block, short anchors or specific anchors are needed; for softer material, longer expansions are beneficial.
If it were me, I would try and attach to the hollow core of the block using stainless steel toggle bolts or toggle wing anchors plus adhesive. Contact with treated wood can cause ordinary steel to corrode.
I'm not sure of the weight involved but 5/16" or larger bolts would be best.
look at picture, appears he has the log screws (12" long) going into block. will the anchor bolts accept a screw? (im thinking no)
/ How to attach to house? #5
No they won't... its one or the other... I am guessing there is wood behind the bricks and he drilled holes through the bricks to anchor it. I don't know if there's a way to know how solid that wood his or to detect studs behind the bricks... but you are right sometime these bricks are simply appearance and are simply standing there.
These are structural blocks. The corners of the house, as I understand, were backfilled with concrete. These aren't near there so these "should" be hollow blocks.
No wood behind. What you see (without recalling measurements) are 4x6 solid "whitewood" (I think they call it). I'm doubting he used any type of adhesive between the wood and blocks.... I'm guessing he drilled into the blocks.
Knowing him, it's possible he "simply" drilled the screw, scored the blocks and then drilled hole into block (as opposed to inserting an anchor) Only way for me to know is to ask him or take apart and look. He's not returned anyone's calls/texts, anything.... his daughter is in wheelchair and isn't a good intermediary to go between.
Personally, this strikes me as an unnecessary "busy project" that the wife created as she's prone to creating busy projects. If it was screwed into wood or sunk into ground, I'd not mind as much but I really don't care to grind down portions of the blocks because you can't undo that.
(turns out yes.... she CAN greatly hide that by splattering some concrete on there and doing her magic..... she's pretty artistic. That doesn't change my mind that I'd rather not grind on house with a diamond wheel)
/ How to attach to house? #7
To be honest go to your local home depot and ask what they have that would give the highest strength .... google say its the link below I know someone who used it for the same exact purpose but I haven't personally used it... then there's a bunch of other examples, I would diffinatly used a insert and my guess is that's what your brother in law did.
/ How to attach to house? #8
First, what is that gray wood on top of the blocks? Is that just a trim piece? Is there a 2x12 or something capping the blocks behind it? If so, I'd get some good structural wood screws like those in the first link below to fasten the top ends of the braces. That's where the "pulling" will happen. Anchors below that will be mostly shear loads and not so much tension. Then something like Tapcons for fastening into the block below. A flathead tapcon with a little countersink wouldn't look bad.
If the fastening is all done in the block, I'd use either the single or double expansion anchors in the second or third link. They're available in different sizes and are for use with machine bolts. Best would be to predrill the wood a bit for a washer. You could use either appropriate length bolts or allthread with nuts and grind off the "leftover".
The last link wouldn't be my first choice, but if the load isn't great they can look more finished than the rest. I'd stay away from plastic anchors except for hanging pictures unless they were for #16 screws. Another challenge with plastic anchors is finding screws that will work with the material you are fastening.
I'd also avoid anchors like the Hilti Kwik Bolts unless you're going into concrete. They depend too much on the tiny claws grabbing into the wall so the band expands and gets tight around the tapered bolt. Block is soft and mortar isn't much better.
/ How to attach to house? #9
Just my opinion but I think 95% of the attaching to the house is happening above the picture. The brace is pushing into the house and the wood you want to screw onto the house is spreading out that pressure over more bricks. So the only thing the 2 screws are doing is a little bit of shear force side to side and possibly keeping the wood from warping and pulling away from the house. The important part, like chim mentions, is the wood at the top of the picture and what is behind it and above it. The screws at the bottom going into the brick are kinda cosmetic.
g
/ How to attach to house? #10
g
I’m thinking same thing. Attach to wood at top.
/ How to attach to house? #12
I think the term isn't 'log'; it's 'lag'. Which is the wrong screw for cinder block. Toggle bolt or 'Molly' bolts would be my choices. And the screws at the bottom are needed for side-shear loads, and they will be carrying some percentage of vertical shear, as well.
/ How to attach to house? #14
If the blocks are indeed hollow, these would work well. I’ve used them for supporting large televisions on 1/2” Sheetrock walls.
SNAPTOGGLE® Heavy-Duty Toggle Bolt — Stainless Steel – TOGGLER
They support up to 802 pounds in concrete and over 200 pounds with 1/2” drywall.
/ How to attach to house? #15
I would not use a wedge style anchor. If it was in the middle of a big slab that would be a different story. If I had to screw into masonry I would use something like this.
/ How to attach to house? #16
The fixing at the top is under tension ( pulling away)and fixed into wood; the bottom is under compression (pushing into the wall), so the fixing requirement is minimal.
/ How to attach to house? #19
It's hard to know for sure with the angle of the photo but.... The top is most likely mounted into the wood, the lower would appear to be mounted in to the solid ends of the block. In those cases a "ledger lock" would be used on top and for the lower a solid type "tapcon" anchor would be fine. I'm more curious to know if he used any joinery (or back screwed and the black bolts are for looks) on the support angles or if the screws there are at an angle. Not clear to me in the photo. Assuming you want to match the look, they do sell black ledger locks and black tapcons that would do it. More important would be when drilling into the block to use the proper tools to not eat the bit or blow the block apart. A bunch of different brands of fasteners out there that'll work. I wouldn't use an expansion bolt on most block, JMO ...
/ How to attach to house? #20
I'd take a hammer and tap on that top cap. You should be able to tell if it is a 6x6, 6x8, something like that. Perhaps you can see the inside from in the attic, or look at the end of the house. Anyway, that may give you a lot of support depending on how well it is attached to the wall.
Then, are those hollow blocks? Or perhaps hollow blocks filled with rebar and concrete?
If hollow with a concrete filler, then you can find any good concrete anchor and drill deep enough to get into it.
I'm trying to envision the leverage. Most of the pulling out would be happening at the top, and as mentioned, just a vertical shear force further down on the support.
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
Volvo VNM (A63689)
Volvo VNM (A63689)
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
2012 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2012 FOREST RIVER...
2024 Ranger XP 1000 North Star (A62679)
2024 Ranger XP...
2019 CHEVROLET 5500HD LCF S/A  4X2 24FT BOX TRUCK (A59914)
2019 CHEVROLET...
