N H Ford 445C TCM no. FONN7Z319AAR.
/ N H Ford 445C TCM no. FONN7Z319AAR.
Soldered all the connections. Then started them up. FWD lit up and REV did not. I carefully checked every connection. The black that doubles back to each controller was not connected. (I assumed that is the ground, but then why did the FWD light up?) So, I assumed it was a problem with the REV controller. So, I hooked up the extra new controller ----- Nothing. I'm tired of assuming, maybe I'll jump off the Tallahatchie bridge. The two local NH Ford tractor dealers don't seem to know the 445C and I'm not prepared to part with a bunch of $. I'm hoping you will ask if I checked XYZ. I'm sure I didn't. Fred
Eric, it's 1pm, I wrote the above an hour ago, ---- I'm going to read the electric and transmission manuals again. Perhaps, I'll find something. I'll let you know.
/ N H Ford 445C TCM no. FONN7Z319AAR. #162
So, just a suggestion Fred, but now might be a good time to give the guy who helped you out last time a call. It sounds like you could possibly either have a broken connection or a wire in the wrong place.
(10/21) Eric, thanks for the comeback with a suggestion. Unfortunately, my friend lives in Connecticut. He comes down on vacations.
(10/23) I think I found a local mechanic. He's coming over Friday. I'll let you know.
/ N H Ford 445C TCM no. FONN7Z319AAR. #164
Excellent. Also have him (or you) check the signal wires from the shuttle switch to be sure it's sending voltage to the right place when the machine is shifted. It should be getting battery voltage at the brown wire in the black plug in forward, and battery voltage at the gray wire in the black plug in reverse. Those wires should be connected to the "Power +" terminals on the individual controllers, Brown on the forward controller and gray on the reverse controller.
Mechanic was a no show. Anyway, I'm taking a break from the 445 and with friends am going to maiden voyage my restored boat and engine Wednesday.
Thank you for the additional good info. Obviously, my main weakness is electrical. I will find a knowledgeable mechanic and with your advice it will be running.
Eric, I'm not clear about the 6-wires coming out the block going to the transmission controls grey and black connectors. I know two wires in this case to the lock-up can be ignored. since the Hanleis are adjustable, is it possible to ignore some or all of that tangled mess between the next connectors at the Hanlei controllers, except perhaps the fuses? Do I make sense? I'm asking for a friend.
/ N H Ford 445C TCM no. FONN7Z319AAR. #167
Fred,good for you, take some time and enjoy the boat! I'm not sure exactly what you're asking about the wires, that's kind of a very general question. Did you at some point disconnect the controllers from the wiring after you initially had them working, or...? The connections are all laid out in an earlier post in this thread, as I recall
/ N H Ford 445C TCM no. FONN7Z319AAR. #168
Fred,
When you say you have fuses and such, are there yellow diodes in that mess? if so, you have the corrected version for the early C models where the computer did not have protection built into the circuitry, so Ford had to update it with a short harness of fuses and diodes. Since you are not using the computer, I think you can eliminate most of the mess. Take a picture of the harnesses with the black and gray connectors laid out to where it can be seen a little clearer.
I have a lot of experience with the C and D series, but not sure I can help completely from long distance.
Most people in the dealerships weren't born when the C was new and those that remember left a long time ago.
Ted
Eric & Ted, oh boy, I'm wolfing down my dinner to get back to you. I took photos today and if you want others, here I am.
/ N H Ford 445C TCM no. FONN7Z319AAR. #170
Fred,
Hope you had a great and restful afternoon on your boat. Don't choke on your dinner over this!
You can throw away that mess with the yellow diodes, relays and fuses. That was a band aid protection harness that Ford had to put on the early tractors because if there was a short in the computer, it could leave the tractor in gear. Most everyone left it in place even when the computer was changed. The newer computers, such as on Erik's 555D, and any computer replacements had the protection circuitry built in, so this mess wasn't necessary.
Most likely, between the brittle wiring of that part of the harness, and possibly a bad fuse, relay or diode, this is what is giving you fits!
Don't work so hard, but keep on working!
Well, I can't cry over spilt milk. My fault I didn't post photos sooner. I enjoy working on things and it feels good to have hope. Eric thanks for continuing to help me, although I didn't give you enough info. Once I succeed with the transmission issue, I'll clean up the mess behind the fuel tank. At least the old parts on the tractor can be replaced.
A story:
A successful MD brought his expensive car to his mechanic for a repair. Since they were familiar, the mechanic asks, Doc how come with so many years of training and experience I have, I still don't make the big $ you do? Don't worry you will, once you are able to rebuild an engine with the engine running.
between naps I wired the two controllers. I turned on the key: FWD did not light up. REV lit up. I turned it all off for another day. I might figure out how to check the FWD controller, but a little enlightenment will go a long way through the process. Once I get FWD working, I will adjust them. I'm a wishing!
Both controllers turned on. It was too chilly to work any further. You folks way up North would crackup if I mentioned, how chilly. Anyway, tomorrow I will adjust them. I have a question: If I push the gear once and adjust #1, do I exit then come back on for two pushes on the gear for #2? Or do i just push the gear one more time after adjusting #1? and once again for #3? I feel I should turn it off then on again to do the next or each function.
/ N H Ford 445C TCM no. FONN7Z319AAR. #174
You can adjust all functions without exiting. Just hit the button to exit after all settings are where you want them. You can scroll through them all after setting each to confirm that they're all correct, then hit the button to exit. And just making sure you have this right: each controller will only light up when the shuttle is shifted into the corresponding gear. They should both power down when the shuttle is in neutral, and only come on when the shuttle is shifted to the gear corresponding to that particular controller.
Yes, I understand the last three sentences of the above, however, I'm shaky on the first two. If I hit the gear say 3 times and it's ok, do I hit it one more time to bring me to item #4? Now suppose I make a change on three, do I hit it 4 times to bring me to #4? I just want to check this out and thank you for your patience. I may know some things, but overall, I know hardly anything!
/ N H Ford 445C TCM no. FONN7Z319AAR. #176
Fred, to know which option you're adjusting, just have a peek at the top display on the controller. The number of the option you're currently adjusting is displayed there. Every time you hit the button it will advance one. When you reach #8, if you press it again, it will jump back to #1 and begin to count up again with every subsequent press of the button.
There's obviously something wrong in my 445C wiring, e.g., testing the input circuits, FWD and RVD I get 00.0. so, there's no battery voltage to the input, but the controllers light up in FWD or RVD. Power is coming from somewhere! I don't know enough to mess around with it.
I pulled down the fuse box and found three wires disconnected or hardly connected. Chapter 5 section D indicates 9 circuits. I've searched but cannot find a fuse box diagram so I can verify fuse sizes and maybe possible wire sizes. It there such a thing?
/ N H Ford 445C TCM no. FONN7Z319AAR. #178
Originally, fuse #21 was the 5 amp ATC fuse that protected the transmission controller.
/ N H Ford 445C TCM no. FONN7Z319AAR. #179
Where are you putting your meter's ground probe when attempting to check for power? Hopefully black wire at the controller? Positive probe is on the gray or brown wire, right? You mentioned being not great at electrical, so maybe we should start there.
Thanks Eric, I was grounding on the machine. I will try the black wire.
I'm on the road again! Eric your instructions did it and Ted, Fuse block #21 had a rusty 10 amp fuse.. ASAP I will cleanup the fuses. You gentlemen put quite a bit of effort helping me along. Thank you,
2016 American Eagle Reel Trailer (A60352)
2016 American...
THREE POINT MAINTAINER BLADE (A58214)
THREE POINT...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
2015 DODGE RAM 3500 4X4 CREW CAB PICKUP TRUCK (A59904)
2015 DODGE RAM...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
