Anyone have a MechMaxx 3-pt stump grinder?
/ Anyone have a MechMaxx 3-pt stump grinder? #281
Is anyone using the SG24 with a Speeco quick hitch? The Mechmaxx website doesn't mention if it's quick hitch compatible.
/ Anyone have a MechMaxx 3-pt stump grinder? #282
I can tell you it works great with my landpride QH16 quick hitch.
/ Anyone have a MechMaxx 3-pt stump grinder? #283
I bought the MechMaxx SG24 and after a month or more, finally used it. Shipping was not an issue, came faster than quoted. Crate is metal and well protected. Checked all torque of bolts and used. Works like a dream. Did about a dozen stumps, ranging from 6" to 36", no issues. Well, one issue, and it was operator error. Left my drawbar on and when I was grinding below ground level, it cut open the plastic sheathing and got into the driveshaft. the driveshaft fared better than the 1 1/2" drawbar. I would recommend this based on my short term use so far. Not sure how many years it will take for me to verify it's a great product, but I'm sure I will get more than my moneys worth. I only wish the chainsaw holder was tall enough to use a bar protector. Maybe I'm overthinking the need for the protector, but I always use it.
Yep, that’s exactly my setup. Works perfectly
/ Anyone have a MechMaxx 3-pt stump grinder? #285
FYI, for anyone that's on the fence about getting one of these. Mechmaxx has their early black Friday sale going on and the stump grinder is listed for $1299.
I just placed an order for some other stuff that was on sale and was able to use a 5% off code from one of their YouTube 'reviewers'.
/ Anyone have a MechMaxx 3-pt stump grinder? #286
I did the exact same thing to my drawbar, but only damaged the plastic pto guard. Easy mistake to make.
/ Anyone have a MechMaxx 3-pt stump grinder? #287
Can you share that code or a link to the video that included it?
/ Anyone have a MechMaxx 3-pt stump grinder? #289
I've been comparing various stump grinders. This thread has been helpful.
Still not sure if the hydraulic types are worth the increased cost.
Same with the bigger flywheel. They can go deeper, but going 6 under should be enough.
The WM has a Pro version that adds a few features like a chain deflector and shock absorption. Not sure if that is worth the extra, either.
The MSRP on the MM and WM are pretty close, but MM seems to have lower sale prices.
I'd love it if one or two 'influencers' would buy a couple of each brand and legitimately put them through their paces.
/ Anyone have a MechMaxx 3-pt stump grinder? #290
If you are doing it professionally then the hydraulic types are worth the money.
Use around the house and farm - the $1299 is awesome and works really well.
/ Anyone have a MechMaxx 3-pt stump grinder? #292
I've got 20 acres that is mostly trees. I'll be dealing with stumps for the rest of my life.
/ Anyone have a MechMaxx 3-pt stump grinder? #293
I have the original WM. It works well and as expected. That said, it's easy to try pulling it through the stump faster than the grinding wheel can chew, which results in the unit swinging from grinding at 90 degrees to more like 70 degrees. One time early on, I angled it sufficiently to separate the PTO shaft...and guarantee you'll only allow that to happen once!!!
Based on similar design, I'm guessing over feeding is likely a common situation to avoid with the MM also.
I would have paid the extra for the WM pro version if it had been available at the time, not even knowing if the shock actually works as described.
The other thing is the outside teeth get the most abuse. I wouldn't even mount the 6 or 8 (?) teeth closest to the hub, and just save them to swap as the outside teeth get chipped down (my stumps are rock magnets!).
Tighten up your 3-pt lift arms, playboy!
But yeah I always go to low range and barely touch the HST pedal, certainly easy to over-pull it and start bouncing around.
And agreed, those interior teeth will never see any action, kind of odd to have them at all.
/ Anyone have a MechMaxx 3-pt stump grinder? #295
I made mine out of 1/2" plate, 3/4" for the wheel, it doesn't bounce around.
I can't even hold my phone as steady as it is.
/ Anyone have a MechMaxx 3-pt stump grinder? #296
Good looking welds!
Although, I'm not sure that qualifies as a stump!
We're did you find your (carbide?) teeth?
/ Anyone have a MechMaxx 3-pt stump grinder? #297
I bought the pro version for my 4410. As far as I'm concerned the shock could use a heavier spring. It does help but could be more aggressive. It's probably ok for a smaller tractor. One day I will play around with some extra springs and see what happens.
/ Anyone have a MechMaxx 3-pt stump grinder? #299
What possesses people to join just to post nonsense?
Vermeer only makes industrial cutters. Unitaskers are better as implements.
/ Anyone have a MechMaxx 3-pt stump grinder? #300
Just curious if you know what the least expensive Vermeer unit costs.
For $1400, the MechMaxx might not be very good, but I doubt I will need to grind down more than 50 stumps in my lifetime as I am 75 now. Have done 7 so far and another 20 to go for my immediate needs. I figured doing the 30 or so stumps would have cost $3000 to have a contractor do it. $1400 seemed a good investment.
When I am done with it, I can likely sell it for $1000 or keep it. It will have more than paid for itself.
Wooden Native American Totem Pole Statue (A61569)
Wooden Native...
500BBL WHEELED...
2016 Lincoln Navigator SUV (A61569)
2016 Lincoln...
2017 Ford F-250 Pickup Truck, VIN # 1FT7W2B63HED67208 (A61165)
2017 Ford F-250...
2006 STERLING ROLL OFF (A60736)
2006 STERLING ROLL...
2013 Chevrolet Silverado 2500 Ext Cab Pick-Up Truck (A60352)
2013 Chevrolet...
