2012 4400 - Rockshaft dead
/ 2012 4400 - Rockshaft dead #1
kalos1972
JD 4400
So my 4400 started having leak down issues with the 3pt. I would have to continually lift the 3pt back up as I worked throughout the day.
Then it started to get so bad that when I did have to raise the 3pt again, it would load the tractor until I came back a tiny bit on the control, and you would hear the idle steady and even out. Also, I couldn't use the front grapple when the lever was all the way back and it was loading the system.
Now yesterday the 3pt is dead, doesnt go up or down, tilt cylinder works, the front loader and steering work no issue.
Buddy is thinking its the cylinder that needs to be rebuilt but I have seen a few posts here about something getting caught in the valve body. Is there anyway to test one vs the other?
1. Does the whole rockshaft assembly need to come off to rebuild the cylinder?
2. Does the fender need to come off to take the valve cover off or do I need to remove the whole assembly for either issue?
/ 2012 4400 - Rockshaft dead #2
Welcome to TBN
Dive into JD parts to explore the different parts associated with the 3ph control and rockshaft.
Hopefully you can get some better understanding what you are coming up against. Also, there are a number of members who have more actual experience and hopefully will see your post and give you better help. Off hand, I think your buddy is on the right track here. Outside chance that an inline screen has come apart and is lodged in the control, but that is just an offhand thought at the moment.
What year is the 4400 ??
Welcome to TBN
Thanks. Not excited to be here...because that means my tractor is broke. :)
Otherwise, found this place from researching my current issue.
Mine is a 2012. Hopefully some others familiar with this line can chime in.
/ 2012 4400 - Rockshaft dead #4
Is your 3pt all the way up and wont go down? .. or somewhere in the middle and wont respond either way?
It wont go up but now sits at its lowest point dead. The top link works but the lift arms dont respond and I can easily lift them by hand.
/ 2012 4400 - Rockshaft dead #6
OK. Being able to hand lift is normal. It sounds like something has come loose - maybe external linkage from the lever, hopefully. Maybe internal to the cases leading to the 3pt hydraulic height control. Check out "hopefully" and maybe youll find some joy.
I checked obvious things like linkage or hoses...nothing obvious. The lift lever move the rod that goes into the control valve, not sure whats happening inside the valve yet though.
One big question I had is can I pull the control valve cover off without removing the whole rockshaft assembly or the fender? Otherwise, it looks like I have no choice but to pull the whole assembly and just rebuild both since I am there...I am hoping for suggestions on tests to narrow it down but...it is what it is. :/
Ok so pulled the rockshaft housing off today.
I bought the parts to rebuild the cylinder and all new o-rings for all
JD didn't give me the cyclinder seal so I have to call them on Monday. Any trick to getting that thing back in? Do I need a cylinder ring tool?
Found a pice of metal screen in the valve body...as others have had found. Cleaned it, replaced the o rings and reassembled. Can tou take the vale body cover off without pulling the whole rockshafter cylinder cover?
Thanks!
/ 2012 4400 - Rockshaft dead #9
The trick for the new rockshaft seal is letting the new seal sit in hot water for a minute or two prior to install. This allows it to stretch enough to install and still spring back. Then you use a hose clamp to fully seat it (a ring compressor would also work) and use either a wooden hammer handle or rubber mallet (handle is easier) to tap the piston into the bore. Be sure to thoroughly lubricate the bore prior to piston installation. Worked great on my 4410, should work great for your 4400.
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
RAMMAX 3324 33" TRENCH COMPACTOR (A63290)
RAMMAX 3324 33"...
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
WEIGHT BENCH, WHEEL & STAND (A63745)
WEIGHT BENCH...
John Deere 8330 Tractor (A64047)
John Deere 8330...
2018 MACK CXU (PINNACLE) (A63569)
2018 MACK CXU...
