2850 M Hydro or Power Shuttle??
/ 2850 M Hydro or Power Shuttle?? #1
mjstef
Gold Member
LS XR3037C
Looking really hard at some left over 2850s because the 2M.50 seems to have jumped a whole bunch of money. really not a fan of hydrostatic transmissions as a heavy equipment operator for the last 40 years and being used to a power shuttle in loners and backhoes so I'm wondering if anybody has tried both of them and has a verdict?
/ 2850 M Hydro or Power Shuttle?? #2
I dont have personally experience with them, but ive lusted after a 2860M power shuttle for a few years...
The power shuttle excels at loader work, moving stuff. Despite the common wisdom, I think its actually superior to hydro for grading, loader work. PTO work, the hydro allows that infinite speed control, while running at the 540 PTO. So, its a use case question.
Power shuttle is awesome for dirt work, cause you add power as you want, like going into the pile, very naturally. The hydro, your running WFO all the time, but the PS, you drive in, peddle in till you slow, lift the foot, and shuttle to reverse, and peddle down again. To me, its just the "natural" way to run dirt engaging.
Running wide open is exactly why I don't really want a Hydro....
/ 2850 M Hydro or Power Shuttle?? #4
Box blade and grading work, same, you can be at half or quarter throttle, and add power with the foot as needed against the load.
Ive never really plowed fields, just some small areas with a small chisel plow (on a small hydro), so with a turn plow or disc, actual ground speed is important to get the effect needed; no matter the current load on the engine; i would "think" a PS is a workable option, but probably straight gear to the ground speed, and run full power throttle no matter the resistance?
/ 2850 M Hydro or Power Shuttle?? #5
I find that the hydrostatic version of this tractor works just great for loader work. No need to operate at wide open throttle since engine power can be easily regulated by the foot throttle. Need more power? Just press more on the foot throttle. Easier than the power shuttle in my experience.
/ 2850 M Hydro or Power Shuttle?? #6
That's only with E Hydro Plus or whatever name the maker gives it. Basic hydro, the foot pedal does not link to the throttle. I do kinda miss my foot throttle at times from the old geared machine when box blading
/ 2850 M Hydro or Power Shuttle?? #7
Power shuttles, some allow quick, easy, gear changes; others do not; so, with power shuttles, you Do really want to try it before you buy one. Some can be jerky, others are butter smooth, even at half throttle between f and r.
/ 2850 M Hydro or Power Shuttle?? #8
Hydro excels at two things (IMO): loader work, particularly when using pallet forks, and bush hogging.
A good powershuttle is decent at almost everything and superior to hydro in almost all of it.
Now, if we're talking about yellow commercial equipment, then that version of hydro trumps everything.
/ 2850 M Hydro or Power Shuttle?? #9
And that above, is why I have trouble saying 100% power shuttle. On a loader, Lull/reach fork/telehandler, some back hoes; its Fantastic. On some older back hoes, you selected gear at a stop, and could shuttle, in That gear only. More modern, you have 3 to 5 gears on the shuttle Shifter, that you can scroll through as needed.
Biggest problem I've always had with Hydro's is you have to order the next higher horsepower than you would with a manual or shuttle because a Hydro sucks the power right out of it. I remember years back renting tractors Bush hog with and the Hydro's would fall flat on their face on a hill. As far as loader work I would need to have an ankle rebuild after eight hours on Hydro.
/ 2850 M Hydro or Power Shuttle?? #11
Just try the Powershuttle of your choice before placing an order. Some are awesome, some, eh, not so much. And the terms arent exactly the same from maker to maker. So, I can't say that LS power shuttle (or whatever they call it), is the same as Massey, as the same as New Holland, ect.
PALLET OF MISC PARTS (A63291)
PALLET OF MISC...
UNUSED WOLVERINE HYD CONCRETE CHUTER (A64281)
UNUSED WOLVERINE...
2005 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61573)
2005 Dodge Ram...
2023 LHD 7000MB Mega Buggy - Only 35 Hours - Kohler Gas Engine - Rotating Dump (A63689)
2023 LHD 7000MB...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
