DK40 front bearing failure @ 1300 hours
   / DK40 front bearing failure @ 1300 hours #111
What was left looked real clean. When it let loose, i was about 100’ from shop. All oil soaked the ground.
Mine looked clean with a slight tint of silver on the top. That has been changed again.
   / DK40 front bearing failure @ 1300 hours #112
Five years into ownership and 500 hours on my XR4150H, the my front right wheel bearing came apart and tore up the outer housing. The tractor has a Modern 66TRG grapple on the front end loader and I typically lift loads of logs at the maximum capacity. Since the failure, I replace front wheel bearings every 500 hours. I'm not confident that I can detect failure before it goes catastrophic. I'm currently at 1500 hours and in the middle of replacing the bearings again.
   / DK40 front bearing failure @ 1300 hours #113
If ghe bearings were going put the wheel would be loose. Jack it ip and see if you can wiggle the wheel up and down on the knuckle. Usually if the bearings are going the wheel seal leaks.
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
2007 Freightliner M2 106 Medium Duty Pac-Man RL10 10 CuYd Refuse Garbage Truck (A55852)
2007 Freightliner...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
16 T/A TRASH TRAILER (A55745)
16 T/A TRASH...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
