What did you buy this week?
/ What did you buy this week? #2,861
Not moonpies.
Look it up.
Canada
Merica
/ What did you buy this week? #2,862
You know... when I was a kid, those moon pies were great, and then they were hard to find. Got some at a small independent grocery, and kinda, ehh, whatever...
When young, if we tagged alone with dad to the auction to sell sheep, we would get some pork rins and a moon pie,
/ What did you buy this week? #2,866
I believe both come in lots of varieties and sizes. ;)
/ What did you buy this week? #2,868
A Tork 1101B mechanical timer from Home Depot. Simple swap for a unit that went bad. Probably should have bought a replacement motor unit, or just the entire module. Cost difference between the module and entire unit was negligible however. The unit switches my detached garage lights on-off.
/ What did you buy this week? #2,869
I have a similar unit on my aerobic sewage disposal system. It has an aerator motor that has to run about 10 minutes each hour. The company that sells the system (Jet) wants $400 for the timer, but you can get them at McMaster for $60.
/ What did you buy this week? #2,870
I switched from the mechanical timers to digital years ago. The digital are far superior in ability to vary run times. I have 4 on my property. Only thing i have to do is remember to check lithium batteries every few years. Also, remembers time during power outage…no pesky resetting dial. Oh, and automatic DST.
/ What did you buy this week? #2,871
What brand do you use ?
/ What did you buy this week? #2,872
I have a confession:
I have three Intermatic T101 timers. Each in a different shed used for holiday decorations. One we put a lot of halloween decorations down driveway and it's wired to an outdoor socket. I set it on at 7pm, off at midnight. It would run up to 7pm then stop! I lubed everything and it takes 20 minutes to fully flip the switch which it wouldn't complete, so I caller Intermatic. Tech said trippers wear out but I thought of that replacing them. He was baffled saying I had tried everything so order T101M which is "the guts"...entire mechanism.
That arrived Saturday! So glad it was fixed...except at 7pm it would stop!
That's when I noticed the terminals "line" and "load"...
Be sure they're not reversed.
/ What did you buy this week? #2,873
Be sure they're not reversed.View attachment 4251647
I had one of those on my pool for a while. Then I found a 7 day version. I used that for about 20 years. Last year I put in a more modern timer that has a built in on/off/auto switch. I like it a lot more.
/ What did you buy this week? #2,874
Ditto. Except the ones I use either plug into an outlet or replace a powered light switch. No batteries.
Three big advantages:
  • You can have almost unlimited schedules
  • You can remotely over-ride and turn on/off at will
  • Your schedules can include variables such as X minutes before/after sunrise/sunset
I have two different brands - Kasa and Hubspace. Both work excelently.
The caveat with such is that they need wifi access to make changes. Once programmed, they don't.
/ What did you buy this week? #2,876
/ What did you buy this week? #2,877
I just received the MechMaxx stump grinder I ordered. I had tractor ready with pallet forks on to unload it, now I'm putting it together.
It came with tools even and it's packed in a steel frame. View attachment 4251769
I love stuff that's packed in scrap metal. Keep us posted.
/ What did you buy this week? #2,879
Save the bottom of the crate to make a dolly for the grinder.
/ What did you buy this week? #2,880
My wife saw the upper frame and said Wow! We can put a plywood top on it and make a nice display table for my Halloween decorations in the living room!
2020 VOLVO VNL760 6X4 T/ A SLEEPER TRUCK TRACTOR (A59906)
2020 VOLVO VNL760...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
4004SFL (A59228)
4004SFL (A59228)
2022 Mack Pinnacle Day Cab Tractor w/ Wet Line Kit (A61568)
2022 Mack Pinnacle...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
2015 Ford F-150 Pickup Truck, (A60352)
2015 Ford F-150...
