Paper Shredding
/ Paper Shredding #1
Gem99ultra
Elite Member
Mid-Georgia
Kubota L3400HST
I'm pretty sure this is the dumbest idea anyone has ever had, but ...
I have something like 150# of documents that I have to shred. My paper shredder can handle maybe 5 sheets at a time. Obviously, this project would take 10 - Forevers. No small task for sure.
So - this hairbrained idea crosses my mind: Could one use their wood chipper for this project?
I'm thinking that, with proper paper feed quantity reservations, the wood chipper just might make short work of this project, leaving me with a lot more time to do something more resourceful.
Your opinion please, yeah or nah.
/ Paper Shredding #3
My chipper wouldn't manage it well, but perhaps one of the smaller chipper/shredder units.
I'd lean towards @Oaktree's suggestion.
All the best, Peter
/ Paper Shredding #4
I would check on shredding services or free events that are offered by banks and other businesses. I went to Office Depot when I was settling my son's estate and the cost must have been reasonable since I don't recall what it was.
I don't think a wood chipper will have close enough tolerances to do an effective job and you might get into jamming issues.
Doug in SW IA
/ Paper Shredding #5
I highly doubt this would work (but I wish it would). Tried feeding newspaper through a stand-alone chipper once and no-go.
/ Paper Shredding #6
If you had a place to burn, that would be my choice. But just know, the stacks of paper will burn slow like logs, not just evaporate like tissue.
Short of that, a mobile shredding service would be the next best option, as Doug mentioned.
/ Paper Shredding #7
I’d check around locally for a “shredding day”. Our town has a mobile shredding service come in and does a free shredding day. They do take donations that go to a charity.
Otherwise, fire!
/ Paper Shredding #10
I use a burn barrel myself. Takes no time at all. Have a stand alone paper shredder for daily use. Its the huge old tax files i burn after holding time expires
/ Paper Shredding #11
Burn barrel for me for sensitive documents. Will say never 150 pounds to burn, at least not at one time
/ Paper Shredding #12
Only time I ran into a situation like that was a couple years ago when my sisters and I were cleaning out our mother's house. She saved every bank statement, brokerage statement, phone bill, receipts/manuals for appliance that were long gone, etc. Easily the amount of paper the OP has.
While one sister was sorting thru the documents and putting them in a box, I was standing at the burn barrel throwng in this stuff a few sheets at a time. Still had to stir it occasionally to get it all to burn. Very time consuming!
/ Paper Shredding #13
here is an alternative method I found from AI
Soaking paper in water is a method to destroy it by turning it into pulp, which is a useful alternative to shredding for secure disposal, especially for sensitive documents. The process involves soaking paper in water for an extended period, and for a more thorough breakdown, you can mix the solution with a power tool to create a complete pulp. Another option is to place paper in a washing machine, where the water, tumbling, and spins will break the paper apart, making the writing unreadable.
Soaking and pulping
  • Soak the paper:
    Place the paper you want to destroy in a bin with water and let it soak for at least 24 hours to allow it to soften and break down.
  • Create the pulp:
    After soaking, use a paint mixer with a drill to thoroughly mix the solution. This will ensure the paper breaks down completely into a pulp.
  • Dispose of the pulp:
    You can then dispose of the resulting pulp, which is effectively an alternative to shredding for destroying sensitive information.
You could also add some bleach to help it break down.
/ Paper Shredding #14
Even in the SF bay area where everything is expensive it's only $11 per bankers box to have a commercial shredder do it. The ones we took in the other day were crammed full, about 30 lbs each.
The AI suggestion to soak it into a pulp would be a ridiculous amount of work for 150 lbs of paper. Typical for AI to confidently produce the worst answer. I usually put people who regurgitate AI on the block list. I'm here for actual human thoughts, not AI slop.
The burn barrel will only take a small amount (compared to 150 lbs) at a time so you don't overwhelm the fire. Paper burns well a sheet at a time but not so well as a thick stack of sheets. 150 lbs is going to take a really long time.
If your wood chipper is a big one that may work but like the burn barrel you'll have to feed in small stacks. It also may not shred it evenly or small enough to be unreadable. Then you will have to collect all the shreddings (from a machine designed spray them) and find a way to dispose of them. A chipper with a throat narrower than the width of the paper will have a harder time feeding the paper.
I think paying to get it shredded is the best option if you can't find a free service that will take that much.
/ Paper Shredding #15
Some people do not have the ability to burn in their area.
150 pounds is only 3 cases of copy paper. 10 reems per case at 5 pounds per reem.
Just because I used AI to do the typing does not mean that soaking in water is not a valid option.
Here are some NON AI references
/ Paper Shredding #16
I'm sorry, but I highly doubt that most washing machines would survive pulping more than a few sheets of paper. A garbage disposal hooked up to an open area seems more of a match in the HP/ream category to me.
A 5 gallon bucket, a mortar mixer, and a hefty 3/4" drill, sure, especially if there was some detergent is in there.
But I'd go for the $11 disposal.
They do make self feeding shredders that can be loaded with a hefty stack of paper, but those aren't exactly inexpensive.
I used to work with a 5HP blender. Yes, that would do shred a slug of paper in seconds.
All the best,
Peter
/ Paper Shredding #17
Now that we are retired we are cleaning out the office of old notebooks from years of working and teaching, old tax and legal documents, and boxes of papers from her parents' house when we cleaned it out. I fill up a 64-gallon Toter roll around garbage can. It has a 224# capacity, it weights quite a bit stuffed full of paper. Any extra goes in bags. I then have a mobile shredder truck from Ark-La-Tex Document Destruction in Tyler come onsite. They dump the can and shred the contents. If needed I refill the can from the bags. Cost was $88 last visit. Time to do it again.
/ Paper Shredding #18
WOW! That is A LOT of paper! I guess it boils down to what you have more of, time or money? $88 does not seem too bad to have that much paper disappear in an instant.
/ Paper Shredding #19
And who gets to clean all that pulp out of the washing machine when you're done? Enough of a mess when someone leaves a Kleenex in a pocket. Gotta love AI. :ROFLMAO:
/ Paper Shredding #20
I had two experiences with shredding.
Had to destroy classified typewriter ribbon. Remember the old IBM Selectrics? You could read what was typed on the ribbon. We cut the ribbon and then fed it into our shredder. The shredder sucked the ribbon out of that cassette...... and then stalled as the the ribbon jammed up the mechanism. Spent the rest of the night using a bent paper clip to pick the pieces out.
Second time I found that in the winter time, the snowblower our company used would completely shred a newspaper hidden it a snowbank. Unfortunately it was the owner's copy of the Wall Street Journal. I took a lot of ribbing over that one.
Paying someone else is a no fuss, no muss, option for me.
Doug in SW IA
2008 Freightliner B2 Bus, VIN # 4UZABRDJ98CZ17952 (A61165)
2008 Freightliner...
INOP/NON-RUNNING 2015 International DuraStar 4300 Lab/Chassis Truck, VIN # 3HAMMAAL3FL514548 (A61165)
INOP/NON-RUNNING...
2023 TAKEUCHI TL8R2 SKID STEER (A62129)
2023 TAKEUCHI...
UNUSED RAYTREE RMSC78 - 78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
