tight/stuck swivel ball end on hydraulic cylinder
   / tight/stuck swivel ball end on hydraulic cylinder #1
dicktill
Gold Member
Allegany NY
'22 MF GC 1723EB nicknamed "Fergie"
Hi all,
I have a 3-point "side link" hydraulic cylinder with a swivel ball at one end. The cylinder itself is fine, but the ball is very tight, almost glued in place. The first fix I tried was to use paint stripper to get rid of all paint on the ball (there was a lot). I've then tried huge doses of PBlaster and Freeze-Off, and I've mounted the ball end to a vice and moved the cylinder "round and round", every-which-way, and it is still way too tight. Anyone have any better ideas to loosen it up, such as heat (where to apply?) or a damned-big-hammer (where-to-apply?) or valve-grinding-compound or ?????
TIA, Dick
   / tight/stuck swivel ball end on hydraulic cylinder #2
Shame to fool with a nice snug mobile joint. If you could just find an application that would make it really work, to its full force capacity, back and forth reversals a few times it would probably settle in and get supple. Im just guessing that eye has never seen anywhere near its design stress.
Additionally, you could try a non particulate surface active metal lube like Militec1.
   / tight/stuck swivel ball end on hydraulic cylinder #3
Hi all,
TIA, Dick
Put it into service and use it.
If you can move it on the bench, it's not tight.
The cylinder is well used, perhaps as much as 150-200 hours of use with a 3-point back blade. The issue with it sticking is that the cylinder body does not rotate and that causes the hoses to rub.
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Online Buyers Premium (A55272)
Online Buyers...
2007 INTERNATIONAL 4300 26FT BOX TRUCK (A58017)
2007 INTERNATIONAL...
2006 Tusk 500 PG-16 Forklift  3-Stage 188in Lift with Aux Hydraulics (A56435)
2006 Tusk 500...
LOT: Coolant Pressure Tester, Fuel Pressure Tester, Amp Tester (A59076)
LOT: Coolant...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56435)
2023 Top Air ATV...
