I give up... What is this A-Frame for?
/ I give up... What is this A-Frame for? #1
Midniteoyl
Super Member
N. W. Indiana
Kioti CK3510SE HST, Ford 3400, Gizmow ZTR, Simplicity 7016H
Looking at this dump trailer, what is the vertical a-frame for?
Never seen that before and just can't figure it out.. Add on maybe? 🤔
/ I give up... What is this A-Frame for? #2
It looks like they’re using it for an elevated position for the winch so they can pull stuff into the trailer.
First thought as well, but then I couldn't tell if the a frame was added on or if it was OEM and they just added the winch for convenience.
Another angle.
/ I give up... What is this A-Frame for? #5
I’m pretty sure it’s a mobile home frame that’s been cut off and welded up there.
/ I give up... What is this A-Frame for? #7
Can the winch be used to help lift the front of trailer if front heavy and hydraulics won’t lift it?
It does kinda look like there’s a ring on the front of the bed that you could hook the winch on.
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
