Pics of rear weights
   / Pics of rear weights #1
weeder
Tuscola Illinois
John Deere 425 lawn tractor
Howdy everyone trying to get ideas on making a rear weight for my 1705 MF tractor. I would love to see some!!
   / Pics of rear weights #2
Do you intend to mount them on the rear axles, rear wheels, or 3-point lift?
   / Pics of rear weights #3
this a GC1705?
if so the GC part matters, lot of MF17xx tractors out there.
   / Pics of rear weights #4
Example... 600 pounds , it's a 2x2x1 foot box filled with concrete (150 pound per square foot)....
   / Pics of rear weights #7
I use the factory 70 Lb wheel weights, they help with rear tire TRACTION, but don't relieve the front axle of any weight ...
I've also added 275 Lbs via the BH frame, mostly for TRACTION when using an attachment on the ground ...
I also designed and built my own rear ballast box to fit my quick hitch to keep the weight forward and tight, for hauling a trailer, but also a tote on the front ...
Actually weighs 707 Lbs
Works good!
   / Pics of rear weights #8
Probably on the 3 point lift
A 55-gallon drum, a cross drawbar, some rebar and concrete can result in this. Put the cross drawbar high enough so you can set it on the ground from the lift - will be easier to hook up.
  • 55 gallon drum on cross drawbar counter-weight - interior view of rebar.jpg
   / Pics of rear weights #9
Cast some PVC pipes into it to hold shovels and such. Maybe a flattened piece to hold your chainsaw. .
Perhaps continue the pipe thru to the bottom so water drains out and don't freeze and crack it.
And I made one that I cast a hitch into it but the next one will be a 2" ID square tube receiver so I can switch drawbars.
I use that hitch all the time.
   / Pics of rear weights #10
I use my rototiller as ballast on my Ford. Often tossing on some wheel weights onto it that came off of a different tractor.
Eventually I may build a steel weight carrier bar, but I don't have one yet.
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2008 Bobcat T190 Compact Track Loader (A56435)
2008 Bobcat T190...
2014 FORD F-250 (A58214)
2014 FORD F-250...
Miller Millermatic 25 Welder, SKU# 907321, S/N MJ260223N, Rated Output-Amperage 200 (A59076)
Miller Millermatic...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
