Obi-Wan-YJ
Member
My XR4145 (manual tranny) is at the dealer today to diagnose low hydraulic power when hot. We suspect that they'll find that the hydraulic pump needs to be replaced. I don't know what labor is required to replace that pump, but, if they have to do that, are there any other upgrades or modifications that I should have them do while they're in there?
Are there higher-capacity pumps available? Should I have a 3rd line added for the front (for a grapple, etc)? Does the labor for adding a 3rd line overlap much with the labor for replacing the pump? Is there anything else I should be looking at in order to save labor costs down the road?
This is a 2016 model with about 220 hours on it. I've only owned it for 1.5 years (50 hours) and have not replaced any fluids during that time.
It's in the shop because although the loader or 3-pt can lift plenty of weight when cold, as soon as the hydraulics heat up, the lift capacity drops dramatically. After an hour running a 3pt tiller, it can no longer lift the tiller off the ground. The loader can carry a single 1-ton pallet down my driveway, but can't pick up the next pallet. Fluid's full & looks good. Filter is new. No visible leaks.
