2023 L3560, 100 hours, suddenly rapping and hissing noise from engine
   / 2023 L3560, 100 hours, suddenly rapping and hissing noise from engine #1
JerkyChew
shopping
So I fired up my tractor today, it's the L3560 with the cab. As I was driving I thought I heard a rapping noise coming from the engine. I opened the cab door and realized that in addition to the rapping there was a crazy hissing noise coming from the engine as well. I shut it off and popped the hood. I didn't see anything out of the ordinary so I fired it up again - Same problem, so I shut it off again in case there's a hydraulic leak or something. It has been sitting in my yard unused for about 2 weeks, but otherwise nothing out of the ordinary has happened to it, and it worked fine the last time I used it. The tractor was just serviced by the dealer at 80 hours and I have the extended warranty so I'll be calling them tomorrow, I just was curious if anybody had any immediate ideas. I know a bit about gas engines but not much about diesels so I have no clue what else to check, if anything.
I took a quick video of the noise. It's a little tough to hear the hissing, at least to my ears. YouTube made it a short for some reason:
   / 2023 L3560, 100 hours, suddenly rapping and hissing noise from engine #2
Sure sounds like exhaust, rather than a mechanical noise to me.
Hopefully it will get straightened out with the dealer quickly.
   / 2023 L3560, 100 hours, suddenly rapping and hissing noise from engine #3
I can’t tell from the video, but an exhaust manifold leak would be my guess based on 8 seconds of video
   / 2023 L3560, 100 hours, suddenly rapping and hissing noise from engine #4
I can't tell in video, but is it just doing a regen? I know my diesel trucks have a distinct and hissing sound when they regen.
   / 2023 L3560, 100 hours, suddenly rapping and hissing noise from engine #5
That's an interesting thought, but my L4060 doesn't sound like that during a Regen. Could still be related to the dpf though.
   / 2023 L3560, 100 hours, suddenly rapping and hissing noise from engine #6
OK, was just a thought because even my Cat wheel loader at work makes a loud hissing while it's doing a regen if you let it drop to an idle.
I wasn't sure if the small Kubota's changed sound also?
Thanks for all the ideas - I forgot to mention that oil appears to be dripping out of the exhaust as well. I'd video it but I don't want to start the thing and risk damaging it further. I've reached out to my dealer and am waiting to hear back. A loose manifold would be great, just because in theory it's not a sign of a larger engine issue. I don't think it's doing a regen because I didn't notice any lights or statuses on the dash, and I just did a regen not even five engine hours ago.
   / 2023 L3560, 100 hours, suddenly rapping and hissing noise from engine #8
Have you done the basics first? Check all the fluid levels? Oil, coolant, etc. Check the air filter? Pull it out and inspect.
So I found the issue - Turns out some critters had made a nest in my exhaust. I was on the phone with my local service department who had me fire up the engine again to confirm it wasn't a loose air filter cover or something, and I realized that the sound was totally coming from the exhaust. I stuck a pokey thing in the pipe and pulled out some hay, so I cranked the tractor RPMs up and it blew the nest across the yard! It's all good now, and I guess there's a first time for everything! Thanks for the help all.
   / 2023 L3560, 100 hours, suddenly rapping and hissing noise from engine #10
Glad you found it before it burnt to the axles!
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
17503-FL (A56857)
17503-FL (A56857)
2009 Kubota RTV1140 (A57148)
2009 Kubota...
LOT: Fill-Rite Pump, Fuel Transfer Tank, Tool Box (A59076)
LOT: Fill-Rite...
SOFTSTART W/ ACROSS LINE BY-PASS STARTER (A58374)
SOFTSTART W/...
LOT OF RIDGE ROW TIN (A58374)
LOT OF RIDGE ROW...
