Top and Tilt l2501 DIY
   / Top and Tilt l2501 DIY #31
My last thoughts on this, I rarely use my side link (using the manual one stinks but it would work for what I need). I built my road down to my creek without it!
Since you have forks, you will most likely not have to use a grapple.
A toplink and a single spool is all you need with your box blade.
TBN is great to talk you into a $1500, 4 spool valve with several buttons!!! You also need to upgrade to a L6060... :ROFLMAO:
I agree, I never have had a need for hyd side link..
I had forks for well over a year before I purchased my grapple and my forks are now seldomly used. Trying to balance logs or brush on forks was a real PITA. The grapple was probably the best investment I ever made for my tractor with the exception of the hyd top link.
   / Top and Tilt l2501 DIY #32
I had top and tilt on my old B2620, it was a nice feature as I had to maintain the road in front of my house.
I have thought about adding a side link for my L2340, but since I no longer have a road to grade I haven't gotten around to it.
My rear blade has hyd tilt anyways, so it's not as much of a necessity.
If you do a lot of road grading with a box blade the side link comes in handy, especially when you have to maintain a crown and you can only grade downhill due to traction! Constant changing of box angle.
   / Top and Tilt l2501 DIY #33
Oh, and the Grand L's are a sweet machine, just saying........
Ha ha...too true. My l2501 is overkill for 5 acres by some opinions but I wouldn't be without it. She actually strains a little picking up a IBC tote full of wet red oak.
I do want to get a 2 spool for the side link also. There are areas, especially the corners of my track where the dirt gets thrown to the outside edge and starts building a bank. The side link adjustment will be perfect for this.
Grapples definitely make the task a little quicker and if I would really get the use out of one I would get it.
The forks work great for my usage. I don't have that much brush etc to worry about. I cut down pine trees and throw them in my pigs yard as they love stripping the bark and needles. Then I throw them back over the fence so they all lie together. Then it's easy to come and grab them with my forks. When I collect any other brush I just park up and get off and throw it all on the forks. Good exercise. And I also use it as a personal challenge to see how much I can pick up with 1 grab.
I also have a pretty good system for bucking trees and I throw the rounds into an ibc tote/cage and then once full take that to my splitter.
I would love to get a grapple to just ride around and pick crap up and move it :ROFLMAO: and 1 day I might.
Yes... I actually first had my heart set on a L4600. So big and mean looking, but that was definitely overkill for my usage.
   / Top and Tilt l2501 DIY #37
Until you get a grapple, you will never understand how much and for what all it can be used for. It's like having a big hand on your tractor.
I cut an immense amount of wood as I use and sell it. I will grab logs with the grapple, or drag them out if they're too long, and take them to the splitter. I then buck them up while holding them with the grapple.. Makes so fast work of the entire process. Once the pile gets large enough, I have my 15 year old twin boys stack it all.
I understand the uses, and in my current situation there isn't a great enough need.
   / Top and Tilt l2501 DIY #39
2010 SHOP MADE DUETZ MARATHON 60KW GENERATOR TRAILER (A58216)
2010 SHOP MADE...
2014 Jeep Cherokee Sport SUV (A56859)
2014 Jeep Cherokee...
Portable Gantry Crane w/ 5 Ton Chain Hoist, 9' W x 12'H (A59076)
Portable Gantry...
2020 JOHN DEERE 444L WHEEL LOADER (A52709)
2020 JOHN DEERE...
UNUSED FUTURE AUGER SET (A58376)
UNUSED FUTURE...
DIRT DOG APP48.3 (3) SHANK 48" SPRING TOOTH HARROW (A58375)
DIRT DOG APP48.3...
