Tire Sealant for Slow Leak
   / Tire Sealant for Slow Leak #11
It will not work in loaded tires though.
Correct, but neither will most other "sealers" there is a sealer that does, but I don't remember which it is ... OP didn't state they have loaded tires...
   / Tire Sealant for Slow Leak #12
Watching. I have one rear tire and one front tire that leaks down.
   / Tire Sealant for Slow Leak #13
HawkinsHollow, before I'd fill them with leak stop I'd jack up the axle, deflate tire, break down the bead and clean mating surfaces of bead of tire and rim.
It's quite easy to sideswipe a stump or big block of wood and run a splinter of wood between tire and rim if the air pressure is too low.
I had to do that a few times years ago with loaded tires, not fun.
   / Tire Sealant for Slow Leak #14
Here is the sealer that works in liquid ballast filled tires ... HYDRO 1500 ™ 5 Gallon | MULTI SEAL
But first, I'd get a spray bottle of soapy water and see where it's leaking, or drive it into a deep puddle of water to narrow it down first ... Tread puncture? Rim compromise/damage? Valve stem?
   / Tire Sealant for Slow Leak #15
Both great pieces of advice! Thanks!
   / Tire Sealant for Slow Leak #16
I find that slime has a tendency to run off after a while parked and leak down. This stuff seems permanent on slow leaks:
TireJect Tire Sealant: Off-Road Tire Protection
I use TireJect in my zero turn and in my Polaris SxS. It really works. I have not had good results with Slime and no longer use it.
Quick story- I was mowing near some old wood and didn't realize that I ran over a nail with the front tire. I saw some strange looking blue thing on the ground. Upon examination, I realized the blue was a puddle of TireJect from the tire. It still holds air, even months later. I have not had to add air nor fix the puncture. TireJect for the win!.
   / Tire Sealant for Slow Leak #17
I'm sure there is a chart somewhere but how much Tireject would you recommend for a rear tire on a tractor?
   / Tire Sealant for Slow Leak #18
There is usually some sort of recommendation on the packaging or their web site. Might pay to buy on bulk of that's an option. I usually use 1 tube in the SxS tires and rear ZT tires, ½ tube in the ZT fronts.
Link to the appropriate web page -
   / Tire Sealant for Slow Leak #19
Slime will help you get out of jam,but when time comes for new tire maybe tube tire tech will be :censored: trying to clean the mess.
   / Tire Sealant for Slow Leak #20
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2018 Freightliner...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2022 Grecer T/A 16ft Enclosed Concession Food Trailer (A55973)
2022 Grecer T/A...
TOTE OF RIMS (A58214)
Set of Heavy Duty Steel Trailer Ramps, 60" Long (A59076)
Set of Heavy Duty...
