PTO Shaft to Gearbox Bolts Keep Breaking!
/ PTO Shaft to Gearbox Bolts Keep Breaking! #181
Any updates?
/ PTO Shaft to Gearbox Bolts Keep Breaking! #182
I have not read the 181 posts, so sorry. Has the clutch been checked to see if it is not frozen and it can freewheel? Also, is there a specific torque on the bolts to give it the slip range you need?. I am only familiar with the type with springs, your seems to have a torsion/compression plate of some sort.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #183
The clutch is bouncing back and forth ( left/right) and after time causing the bolt to break.
I would guess there is some wear in the coupler on the clutch and maybe on the the gearbox shaft were the bolt goes thru.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #184
sounds like the Bearings on the pinion shaft are gone
/ PTO Shaft to Gearbox Bolts Keep Breaking! #185
** Rephrased for clarity** So if you loosen the bolts around the metal clutch plates, will the inner clutch disk rotate independently from the front and rear plate and freewheel?
/ PTO Shaft to Gearbox Bolts Keep Breaking! #186
Seems to me somewhere in these 19 pages the OP said he put in a longer bolt and hasn't had the issue since.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #187
Yes, he did. And, I think, said he would update with events. -- Its been a while; no news, good news? ... Probably.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #190
Yep. And from post #3 of the 189 posts so far:
"(Ideally, the unthreaded section would span both sides of the shear circle.)"
Sorry for no updates but been out brush hogging and mowing every day.
The cutter is still breaking bolts. Not frequently but is breaking them.
I think the grade 2 bolt I put in lasted longer!
I am going to try a different PTO shaft and see if it helps.
May just be the way it is.
I carry bolts, nuts and wrenches with me so quick change when it breaks. I actually did shear one bolt the other day.
For other questions - the clutch is in good condition and functions fine.
Gearbox is fine and input shaft is tight, no bearing play.
Thank you to all for the input.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #192
Would it be possible to get a picture of the bolt and surrounding mechanism so we are all sure to be talking about the same thing? I have seen bolts holding flange faces together, flange faces with only one bolt holding them together, sleeve couplers with shear bolts through the shaft and sleeve, etc. I don't know exactly what the arrangement is that's causing the problem.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #193
post #56
/ PTO Shaft to Gearbox Bolts Keep Breaking! #194
Honestly the only thing I can think of is that your "slip clutch is adjusted correctly" isn't.
When's the last time you checked it?
It is fine. I completely disassemble and clean every spring, and it is checked every month. I do this with all of my slip clutches.
It is not "shearing" bolts they only break on the threaded side where the nut is.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #196
Here are the last three that broke. 2 grade 8 and 1 grade 5.
This is a lighter duty cutter and I don't push it hard. I engage and disengage the cutter with engine RPM at about 1500.
I use it mainly for doing fields that are in good shape and just cutting the field grasses.
Most of the time it is areas that I do about once a month to maintain. Next step would be a finish mower or mid mount and mow a little more frequently, but the customers don't need it cut that often.
It's obvious to me the threaded portion is breaking. FWIW I use 3½" bolts, it is a bit too long so I use a heavy flat on each side of the PTO yoke and torque the nut to maximum recommended.
Every gearbox shaft I've touched is hardened steel, good luck doing any machining to the shaft.
IMO you should lighten up your slip clutch a bit, breaking bolts is telling you something.
it is only breaking one side so it is not actually shearing them. I did use a 3 1/2 and it lasted longer but did eventually break. I think the grade 2 bolts are lasting longer than the 5 or 8's.
Also, they are breaking while mowing nothing more than regular field grass. Cutter is not taking any hits. Not that it is breaking them every day but enough to be a trend and not random chance!
When I am mowing this stuff it barely even affects the RPM it is so easy to cut.
I'm going to change to another PTO shaft and see what happens. Might just be the combo isn't aggregable.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #198
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
1995 John Deere 7400 (A60462)
1995 John Deere...
2025 Polaris Ranger XP1000 (A60463)
2025 Polaris...
2018 RoGator 1100C (A61307)
2018 RoGator 1100C...
KUBOTA MX5800 TRACTOR (A62130)
KUBOTA MX5800...
Freightliner Columbia (A61307)
Freightliner...
