Theft / safety lock
/ Theft / safety lock #1
coolbrze
Gold Member
VA
Kubota MX5800
May be a stupid ? but what would you say are the best ways to easily disable my Kubota MX5800 tractor from starting when I go out of town? It's safe where I live but I'm still always worried about some jackknob trying to steal my whip :) Appreciate it!
/ Theft / safety lock #2
Parked indoors? Outdoors?
A remotely-monitored home security system with a combination of door, window, and motion sensors is pretty hard to beat.
I have a sensor on each door of my barn, as well as two interior motion sensors, with a monitoring contract with a company that is almost too responsive. It'd be pretty hard for someone to get in or out without the police being notified, and at least in our neighborhood, the police respond to these calls.
If parked outdoors, I'd probably just glue or screw the two halves of one of the wireless door sensors to the hood of the tractor, such that it triggers an open door alarm when the hood is opened. Heck, you could do the same on the clutch or brake, if entry by hood is less likely, or to the door of your closed operator's station.
Even if the police are not responsive in your area, you get a notification on you phone when the sensor is triggered, and a call to your favorite enthusiastic neighbor can be made.
/ Theft / safety lock #4
I used to pull the main fuse, 40 amp. Some people would put in a blown 40 amp in it's place. I wrote PTO "Off" and "On" in the opposite locations... then leave the PTO on (for my tractor, that will not allow it to start...)
Out of sight and behind locked doors help but it's not foolproof.
A rollback will drag and load your tractor faster than the police can get there. Make sure you have insurance.
Thanks guys - it's parked inside in a locked shop & I've got cameras but still worry about it. Always trying to think of other ways to protect my stuff but I reckon when it comes down to it, if someone want's it bad enough, they're going to find a way to get it...
/ Theft / safety lock #6
It's only stuff. If someone gets into the shop where I keep my tractor, I have a feeling that replacing the tractor is going to be one of the easier parts of the resulting insurance claim.
Tractors are easily-quantifiable items, and even more easily replaced, than things like antique machines and hand tools passed down from your great-grandfather. I have no great sentimental attachment to the new tractor I bought 5 years ago. :D
/ Theft / safety lock #7
This
This is doubly true if you were to confront a thief during a robbery. Injury, from whatever means, to the thief or yourself could be VERY costly!
/ Theft / safety lock #8
When I was tractor shopping 1 owner had a keyed battery cutoff switch that he had installed on the frame, under the battery.
He told me all the kubota keys were basically the same and wanted a little more protection.
That's about as cheap and easy as you could get, other than the PTO switch idea.
I imagine you could also install a car alarm/immobilizer to interrupt the ignition circuit.
Maybe install a remote start whilst you're at it :) now that would be cool, but obviously wouldn't work.
/ Theft / safety lock #9
Instead of or in addition to the battery cutoff switch, install a hidden switch to the glow plugs ... Gonna be hard to start without them working ...
/ Theft / safety lock #10
Not in warm weather, at least I don't need it on my Bota and the LS does not even try to activate the glow plugs above 75 or so...
/ Theft / safety lock #11
I just got my Kubota, so not familiar with its "normal" . . . I let the glow plugs light go out, but "usually" is only a couple of seconds though ... However on my little Massey, even at 70°+ it needs a good 15+ second glow first start of the day, and then it cranks a bit, and stumbles to a start with a white then black cloud ... Done it since new ... At 10° it takes a few tries with 60+ seconds of glow ...
/ Theft / safety lock #12
My older Yanmar would only run glow plugs if temperature was under maybe 40F. But the new one doesn’t runthem until temps are down closer to maybe 20F.
In either case, just turning the key starts the machine, glow plugs or not, and it never has any serious trouble firing, when I forget to wait and do that, usually first cold morning each fall. It may not sound real happy, but it starts!
/ Theft / safety lock #13
I have a battery cut off switch. it's not easy to see unless you open the hood and if your looking for it you can see where the battery cables go to the switch.
/ Theft / safety lock #14
I carry farm insurance. It covers motorized and non-motorized equipment, out-buildings, medical on trespassers, and an umbrella rider. I do have to keep the ins. co. policy updated for changes in equipment etc.
They just paid for removing debris and building a new pole barn in the same spot after a Jan. storm blew 2 large trees onto the old barn.
Yes, my ins. premium went up, as expected, but I don't trouble myself with anything being stolen or burned up.
If the key to something stolen is in my pocket or key box in the house, I don't worry.
(8) Used John Deere Hydraulic Cylinders (A65640)
(8) Used John...
John Deere 660 Hay Rake (A65640)
John Deere 660 Hay...
Brillion Cultimulcher (A66408)
Brillion...
2022 ALLIANCE NORTH AMERICA AIR MAN SDG 25 GENERATOR (A65643)
2022 ALLIANCE...
NexTier Frac Manifold T/A Trailer (A64194)
NexTier Frac...
2016 Husqvarna DRT 900H Tiller (A66408)
2016 Husqvarna DRT...
