Echo CS-500P any good
/ Echo CS-500P any good #1
rangerfredbob
Dayton, Oregon
Kubota L260
Just a general question, I've had great luck with Echo engines and I know they can generally keep up with the bigger guys for the most part... Anywho, saw a CS-500P on marketplace for $40 and couldn't pass it up, it has a broken kill switch (they bumped it and now no spark and the switch is wobbly so just shorted) but has good compression and looks in good shape... My normal go to acresinternet doesn't show that model specifically and not much showed up on my quick search... Looks like it's likely about 10 years old which doesn't sound bad... Unless it's a secondary air injection type 2 stroke or something dumb I'm not too worried about the fuel system, I have plenty of parts to fix most standard weedeaters/chainsaws on hand :)
/ Echo CS-500P any good #2
Good find! I've found a couple of cousins, CS-400's without bars. Cleaned them up and added bar and chains. Run great and light weight for the power!
Dug into it this morning and was able to get the kill switch working, it's convenient being handy... Checked the metering diaphragm and it would have been fine if I hadn't stabbed a screwdriver through it prying the cover off... It's a runner but I need to strip and clean the carb as the high speed circuit seems to be plugged.
The sticker says it's an '11 model, still the newest saw I have... I'm curious if it has any hours on it, chain looks new, the Echo paint on the bar is worn off but the black paint is there. Was either a truck saw or they just changed the bar and chain recently.
Looking a bit more this seems to be past the homeowner grade stuff so that sounds good to me! Sounds like it was in the $450 range when new... If it's anything like the SRM2100 weedeater I got for free and have ran countless gallons of fuel through it should be good...
/ Echo CS-500P any good #4
500P older series like my 490.
500P is just the upgraded version of the 490. Better metal handles with rubber coating etc like the 4910 going to a 501 was.
Great buy though. When new were 400-420 retail.
They are pro grade built with mag cases etc.
Muffler mod is a must on these. Their muffler is so restricted. Takes you around 10min to 30min if never done it.
/ Echo CS-500P any good #5
My 490 muffler looked like this. Guessing 500P does too.
Remove that deflector and pop that little piped restriction out and toss it. Then put deflector back on or go 1 step more and open front of deflector up like I do. Retune carb then.
Thanks for that! I'm going to go do that here shortly...
I just spent a few minutes on it tonight, pulled the carb again to make sure it was all clean and good, popped off the needle restrictor plate and stuff so I could cycle them and checked the pump diaphragm which looked ok but was black fiber so I changed it to a blue one I had around for good measure... slight tweak and it runs like a top!
Doesn't matter what it cost new, I knew it was worth the $40 :), my only other saws are Homelite XL's, Poulan 40cc jobbies and an old Homelite XL330... this should run circles around the 330... The Poulan/Craftsman saws are fine but I rely on firewood so needed a good saw and the right deal finally fell into my lap...
One of these days I'll get all my old random yard/estate sale find saws out and hang them on the shop walls and get a list of them and hopefully have time to dink with them as some are pretty interesting like the old Homelite XL1 I think it is... told myself years ago $10 or under on a chainsaw would likely go home with me... stopped acquiring the Poulans and got pickier over the years...
You sir were not kidding, that stock muffler was super restrictive! They cheapened the muffler up a bit from your pictures as mine doesn't have the "bolt retainer plate" and the outlet baffle is like the top picture of the new muffler with just the small slit on the front facing side and the three louvered baffles. I ended up taking tin snips to the baffle and adding another slit and folding the whole thing out, of course left the spark arrestor screen in place. But man did it wake the thing up! It can breathe now! Throttle is super responsive...
On the plus side I took the muffler off to do this since I couldn't get a screwdriver to the bottom screw but in doing so I saw the shape of the piston and cylinder walls, they're cherry, look pristine and new, it has an Oregon chain on it that doesn't look like it's had a round file to it, I wonder if they didn't put an hour on it and just keep it around... super glad I jumped on this thing...
/ Echo CS-500P any good #8
I like tan 1st, black 2nd. Then blue only if I have no other choice. Black before blue always if I have a choice of the 2 when brand new.
Tan best all round, black next best IMHO for flow.
/ Echo CS-500P any good #9
You didnt remove the outer deflector to remove the inner small restriction pipe? Just 2 screws hold outer on on older muffler.
Watch opening the sides like it sounds like you did. Will blow hot exhaust right on the plastic brake handle and possibly melt it when being used alot.
Reason for opening the front of the deflector.
Then my newer 501 muffler on how I do front deflector after remving that little inner pipe.
/ Echo CS-500P any good #10
That was a great find! 👏 And I see there's still parts available for it--Even the labels. I found Jack's Small Engines but I'm sure there are others.
/ Echo CS-500P any good #11
I don't like the kill switch. The choke will stop a saw just fine. It's way too easy to leave the kill switch off and flood your saw the next time you try to start it.
View attachment 4079945View attachment 4079946
I did basically like your bottom picture but just with a simple clip with tin snips and pliers to fold the flap out, left the flap to keep the exhaust going forward, the louvers on the side I left alone.
On the pump diaphragm it had the black but since it didn't run right I didn't trust it, felt stiff at first and was kinda grody on the carb side... I have a gross of parts on hand so all 3 were available but found the blue first in an open kit... brown is my preferred as well.
Yes, choke is a good backup for a kill switch, long ago I got in the habit of turning the kill switch back on after the engine shuts off so everything is ready to go when I get back to it then I check it when I go to pull it again... modern ignitions are stronger than the older stuff, harder to foul a plug...
Let this thing eat some wood today and had to adjust it, it's a hungry thing! It's definitely a good runner. Still have some tweaks to make and since I ended up about a turn out on the high needle I might change the pump diaphragm to a brown one... and check on the regulator lever level... although I think these needles are a finer thread than I'm used to, it was 4 turns out when I pulled the restrictor out...
/ Echo CS-500P any good #14
@rangerfredbob H side 3 1/8 is stock carb setting out from lightly seated. For 490 500.
Fine tuning it after opening it will give or take.
Even stiff carb dias could caused being out to 4.
I dont know if 500 rev limited like 490 by coil. But somewhere in 12's is good on my ported 490.
Here is carb info from echo. They want ya at 11.4k in this. Mine 12ish.
Check plug after tuning right and running awhile for look see.
  • echo490500carb.pdf
/ Echo CS-500P any good #15
So how much louder is it after the muffler modifications ?
/ Echo CS-500P any good #16
Not really very much at all. My dads stock poulan 3300 louder and stock 346 of mine louder still.
Listen mine is open without the restrictive pipe and opened front deflector like I showed.
The 346 sounds louder still with stock muffler. It got opened after this video.
/ Echo CS-500P any good #17
Doesn’t seem to loud in the video.
My Echo is the 400, i would say it’s pretty quiet but it also doesn’t have much power, a 350 Husqvarna will make it look silly.
My main saw is Husqvarna 562, it’s way louder than I prefer so I usually wear helmet with eye protection and ear muffs.
/ Echo CS-500P any good #18
Amazing what a extra 12cc of saw will do.
400 clamshell 40cc saw to the 350 52cc if the later ones and 50cc if early ones.
Owned a few 350 to know they dont compare to a 400 honestly. Not even in the same ball park.
I have no real reference on how much louder as I did that right off... but that said I ran a whole tank through it yesterday and don't think it was any louder than the 40cc Poulan I'm used to... other than it chewed better :).
I don't have a tach, was just tuning to smoke and gave it enough to let it run right. Will pull the plug at some point after the next tank of fresh fuel...
This saw is pretty sweet, the chain is now dull though... cutting through dry lumber and ash trees that have been dead for a few years isn't easy...
TIRE RACK WITH DIFFERENT SIZE TIRES/WHEELS (A68842)
TIRE RACK WITH...
2003 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2003 FORD F150...
PALLET OF MISC TRAILER PARTS (A68842)
PALLET OF MISC...
Unused 2021 Berti 112in. Handy 230-280 Hydraulic Flair Mower Tractor Attachment (A66734)
Unused 2021 Berti...
2008 SHOP MADE (A68842)
2008 SHOP MADE...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
