Anyone else have an unusually large number of hummingbirds this year?
   / Anyone else have an unusually large number of hummingbirds this year? #1,301
Well, we could use some help keeping the feeders filled.
   / Anyone else have an unusually large number of hummingbirds this year? #1,303
I don't know how you get so many birds at your feeders. I have one at a feeder at a time and an occasional double.
I think a lot also depends on the other food sources in your area, and whether there is cover for less dominant individuals to watch from.
We can have a dozen females happily feeding together and four or five males dogfighting for the feeders. To help keep the peace, we try to spread the feeders out, but the male Anna's can be quite territorial, though not as much as the rufous, at least here.
All the best, Peter
   / Anyone else have an unusually large number of hummingbirds this year? #1,304
I'll try to give you some perspective on the layout of our land. We have been at this place since spring 2017. We may have had two to six feeders the first year with so-so numbers. We are on a narrow ridge, trees on three sides, very steep if not near vertical drop off all around. The first photo was taken on the far end.
Getting a bit closer, the trees on the right are maybe 100 feet from the house. I see the birds flying back and forth to those trees a lot.
The metal porch roof is not much to look at but it was easy to hang unistrut from to hang the feeders. The feeders are hung close to each other. We mostly keep the same feeder in the same place though I will move a couple if the birds are forgoing one. We discard unused sugar water regularly while the numbers build. We are meticulous with our mixture (1/4 ratio). Our county water is well, yucko. We buy Crystal Springs brand bottled water from Walmart. ($1.43 gallon) as there is no limestone in it which stains our electric water heater. We usually have to clean and fill all of these feeders daily. We clean with just hot water and a brush, no soap. We inspect for any black build up. There is no shortage of spiders, ants, bugs, etc. in south central KY. Not sure if that helps the birds, certainly not us, lol!
The thin tall feeder to the left of the first feeder on the right is their preferred feeder. Go figure as they are not baffled so after filling, we flip them as quickly as we can but do lose water in the process. Between the feeders and the deck rail you can see a blue object in the background. That is a plastic tub cut down to hold water. We have a solar powered fountain in it that the birds like to fly through.
Sorry about the lengthy post. Hope it helps.
   / Anyone else have an unusually large number of hummingbirds this year? #1,305
I have swarms of them here in Nevada - I usually have to mix up a quart of nectar a day. Four feeders set up - two on each side of the house - to make the territorial males have to work at keeping other hummingbirds away. Got some great video of them swarming the feeders but I can't post it on here.
Biggest problem I have with the little buggers is that they like to come into the garage with me, buzzing around and checking to see what I'm doing, I guess. But when it comes time to leave, instead of flying out any of the big bay doors that are open they fly straight up to one of the skylights and beat themselves against it trying to get out. I have to use a butterfly net to snare them and turn them loose outside.
   / Anyone else have an unusually large number of hummingbirds this year? #1,306
What kind of hummers do you have there?
   / Anyone else have an unusually large number of hummingbirds this year? #1,307
No idea as to the type/species. There's really tiny ones and some bigger ones, some very colorful. Don't know anything about them but I love having them around.
Excellent post. We duplicated some of your locations and felt we got a pickup in activity. Can you tell more about the misting spray and maybe a picture? I have heard they will fly through a mist but don't know how to have a mist spraying like that.
   / Anyone else have an unusually large number of hummingbirds this year? #1,309
I'll post a photo tomorrow. It's just a simple setup that I cobbled together. There are more custom misting baths available.
   / Anyone else have an unusually large number of hummingbirds this year? #1,310
Sometimes when I water the garden the HB will come and play on the spray as long as it is more like a mist. Not often, but it's fun to watch when they do.
Bobcat 435 FastTrack (A60462)
Bobcat 435...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Massey Ferguson 92” PTO-driven rear-mount snowblower
Massey Ferguson...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
