How Much Damage to the Kubota?
   / How Much Damage to the Kubota? #12
I have never heard of pto brakes. I have always had older tractors on pto work. When did pto brakes come in?
   / How Much Damage to the Kubota? #13
JD tractors with 2 cyl engines with independent pto's began having pto brakes in 1956 which continued into the new Generation 10 series tractors in 1960
   / How Much Damage to the Kubota? #14
I highly doubt it has any damage to the PTO clutch in 200 hours even if he didn’t lower the RPM to start and stop it.
   / How Much Damage to the Kubota? #15
I’d probably be more concerned about starting a heavy PTO load during really high RPM.
   / How Much Damage to the Kubota? #16
Farmall 400 had one in 1950's
   / How Much Damage to the Kubota? #17
I’m guessing that the line on the dash the power is referring to is the 540 pto speed line (about 2300 RPM if I remember correctly). I doubt that anything is wrong at this time with the low hours on the machine. I have done this once or twice myself and everything is fine.
A tiller "out of the ground" isn't much of a load on a tractor PTO clutch...
As for the pto brake, IF, I had one wore out, I'd leave it wore out! I hate the things!
SR
Can you explain more on why? I can't think of a downside to having a working pto brake.
@haydude - is that because if you wore the clutch out you couldn't use you attachments effectively, where as a worn out brake doesn't stop you from using them? Is that why you said that? I agree if that's what you meant....
Thanks for the feedback guys. I think I'll have him hook his shredder up when I go look and see if I can tell anything. It's a basically new tractor, and for what he wants, I want it all to work as it's supposed to.
I bet lots of homeowners/hobby farmers who go out and buy a new tractor are putting undue wear on their machines in 1 way or another. This tractor also has hooks welded on the very outside edge of the bucket..... I've explained why both these things are a bad idea and he shouldn't do that to his soon to be delivered new Kubota....
   / How Much Damage to the Kubota? #19
Its one thing to do it with a hay rake, but much more serious if running a rototiller or auger buried in dirt.
You can overheat and warp the clutch packs instantly.
I did it and couldnt believe it.
   / How Much Damage to the Kubota? #20
SR
Yeah they really don't matter all that much compared to burning up the clutch packs on start up.
2025 AGT MX15RX Mini-Excavator with Dozer Blade (New/Unused) (A59225)
2025 AGT MX15RX...
(APPROX. 20) 4' X...
CORN SHELLER MOUNTED ON WOOD BOX (A58374)
CORN SHELLER...
2012 Ford Fusion (A56859)
2012 Ford Fusion...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
CAT 336E (A58214)
CAT 336E (A58214)
