Gurgling noise
/ Gurgling noise #1
Leonard malone
Kioti ck 25
I've noticed lately that when I shut my tractor down there is a gurgling sound. Any ideas? Thanks, Len
/ Gurgling noise #3
Hydraulic fluid returning to sump and breather is burping
/ Gurgling noise
Is that normal, I never heard it before.
/ Gurgling noise #6
Once yu shut it off, have a good look and see if antifreeze is being pushed back into the overflow bottle.
I had that and it was a head gasket. Exhaust gasses were pressurizing the cooling system.
/ Gurgling noise #7
Hay Dude is probably correct, but another thought is you are running borderline hot or overheating due to low fluid in the radiator.
/ Gurgling noise #8
I also had that happen, and in my case, the problem was simple and cheap.
I had regularly blown compressed air into the radiator to clean out debris, but there was still gunk that wouldn't come out. When the tractor was cool, I sprayed the radiator with a hose to clean it off better, and the problem went away.
For the OP, does this problem only happen for you after heavy use?
John Deere 5M Series Tractor Loader Frames (A65640)
John Deere 5M...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
2004 STRICK 53X102 T/A DRY VAN TRAILER (A59914)
2004 STRICK 53X102...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
48x4 Mini Skid Trencher (A63689)
48x4 Mini Skid...
