Another mouse rant...
/ Another mouse rant... #1
Mtsoxfan
Newark Vermont
Kioti 3520SEH Holland TC29D
I'm a longtime mouser, so this is just an semi-rant. I found a mouse nest just in front of radiator screen, of my new tractor, yesterday while cleaning hay seed accumulated from brush hogging a field. Took me a minute to figure out some of the material it used to build. From a roll of underlayment I just couldn't throw away when I moved from CT to VT. You know, I may have a use for it some day. :eek:)
I usually keep the hoods open of my tractors, as mice love privacy. Since I moved to VT, I stopped using poison, as I don't want to harm natural predators of mice. I know I have ermine, fox and coyotes around home. I use snap traps with peanut butter. Successful enough for me. When I catch mice, I just put body outside barn to attract predators. ( Ok, no real farmer would call it a barn, due to the size, 20x20x20, but that's what I call it to differentiate from shed) It is the time of year though for me to stock up on snap traps, as after a couple of kills, they fall apart. I don't have a problem with catching mice, and they are under control. it's just time to start the dance. Seems like it was a short summer around here...
/ Another mouse rant... #2
They seem to be getting shorter and shorter. Sometimes I think that July and August must have been removed from the calendar.
And I know just what you mean about mice. I also have red squirrels to contend with, and they are even worse.
There are red squirrels around the area, luckily, none at my place. knock on wood. A friend 3/4 mile as crow flies has issues with them. He can keep them...
/ Another mouse rant... #4
My tractor has been sitting outside for a couple years due to too much stuff in the barn. I always keep the hood open when parked.
/ Another mouse rant... #6
All of which brings to mind the classic joke about a bear attack: "I don't have to out run the bear, I just have to out run YOU."
If you look at cabins in Alaska or Canada in bear areas, many of them are beefed up to keep bears from being able to get it. To me, it is like fire resistance; it is another expense, but the price of being where we are.
@ultrarunner To me it is about making your place less attractive than your neighbors. If they have come through your siding once, what about covering the siding with stone or cinder block up four or five feet to keep the bears at bay? You can also get some nice galvanized steel hurricane panels these days to bolt up over windows and doors, which would also add to the cabin's fire resistance.
All the best,
Peter
/ Another mouse rant... #7
From the experts… bears look for vacant homes to set up a lair… squatters as you will with squatters rights?
No food whatsoever remains in the cabin.
/ Another mouse rant... #9
I like barn cats, don't gotta re-set them! 😂
Good seat warmers, too!
/ Another mouse rant... #10
Talk radio left on?
Could try it but standard practice is power off at the main as well as propane at the tank and water at shutoff.
/ Another mouse rant... #11
Solar powered emergency radio?
Just trying to help your cabin not be the low hanging fruit.
Red pepper flakes all around the cabin?
All the best, Peter
/ Another mouse rant... #12
I’ve had good success with the sticky traps.
/ Another mouse rant... #13
My cousin used to live in the Big Pines Redwood Forest area. He used an electric fence to keep bears out, those things can be solar powered with backup batteries nowadays.
/ Another mouse rant... #14
One time I left the hood up on the Kubota..............then some birds built a nest up against the fire wall.:rolleyes::rolleyes::rolleyes:
Cheers,
Mike
/ Another mouse rant... #15
Anyone tried 'Repels-All' by Bonide? It kept critters from my corn this year and more recently I've had small birds going into my truck grill and tire wells and leaving droppings. The Repel I sprayed down inside the truck grill and in the wheel wells has seemed to have kept the birds away. I may try it in the engine compartments of the truck and tractor when Winter gets closer.
/ Another mouse rant... #16
Have you smelled it?
It repels me, too. "Egg yolk solids" translates to "rotten egg", at least for me.
All the best, Peter
/ Another mouse rant... #18
Mice and rats out in force this year.
Can no longer buy locally the good Decon for crawl space use.
I’m getting good at foundation vent replacing…
12 Ton Hydraulic Bottle Jack (A64557)
12 Ton Hydraulic...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2019 HYDREMA 922F HM ARTICULATING DUMP TRUCK (A65053)
2019 HYDREMA 922F...
Smalline 4in. Double Diaphragm S/A Towable Trash Pump (A64553)
Smalline 4in...
2016 Nissan Altima Sedan (A64557)
2016 Nissan Altima...
2018 GMC Sierra 1500 SLE 4x4 Crew Cab Pickup Truck (A64556)
2018 GMC Sierra...
