Aug 24, 2025 / Cub Cadet #1 X xavier56 New member Joined Aug 24, 2025 Messages 2 Tractor Cub Cadet Hello all I am looking for the Torque Specs for a Cub Cadet AX90HUB Engine 547 cc to do a rebuild Note the Engine Rod Bolts came loose. Not sure why Replacing Rod and Crank Thanks
Aug 24, 2025 / Cub Cadet Thread Starter #2 OP X xavier56 New member Joined Aug 24, 2025 Messages 2 Tractor Cub Cadet Hello all I am looking for the Torque Specs for a Cub Cadet AX90HUB Engine 547 cc to do a rebuild Note the Engine Rod Bolts came loose. Not sure why Replacing Rod and Crank Thanks Quote Reply Report Edit
Aug 29, 2025 / Cub Cadet #3 R Richard001 Veteran Member Joined Jun 25, 2015 Messages 1,855 Location Plymouth, MN Tractor Jd lx178 xavier56 said: Hello all I am looking for the Torque Specs for a Cub Cadet AX90HUB Engine 547 cc to do a rebuild Note the Engine Rod Bolts came loose. Not sure why Replacing Rod and Crank Thanks Quote Reply Report Edit Click to expand... Welcome to TBN. What is the model number of your tractor? Richard
Aug 29, 2025 / Cub Cadet #4 T tomplum Elite Member Joined Jan 30, 2017 Messages 2,911 Location PNW Tractor XJ2025H This work for you? Attachments powermoretorque.pdf 75 KB · Views: 90
