The Life of a Custom Mowing contractor
   / The Life of a Custom Mowing contractor #1,651
We also drove the “Road to Hana”.
I drove about 50 miles of switch back roads to get there.
When we arrived at the town, it was just a small village, some nice homes and a small lagoon/harbor with a canoe club.
It was pretty scary. Some single lane, lots of pulling over to let oncoming cars go by.
Pretty drive. I wouldn't do it again. We went through the rain forest and returned on the southern route through the desert. That was an adventure. We like Maui. Have been 3 times but I like Kauai more. Nort Kauai is more of my kind of relaxation. I love the wild chickens.
   / The Life of a Custom Mowing contractor #1,652
HD, I have a question. I went to NC last week and saw someone cutting hay with a 15' rotary cutter. What's the downside to that vs a standard mower/conditioner?
Biggest would be, as you know, the rotary mower shreds the grass into small bits & pieces which are nearly impossible for the baler to pick up and build into flakes in the baler’s chamber.
A hay mower cuts the grass off about 5” high, leaving those nice long strands the baler can easily pick up and put into a nicely shaped bale.
   / The Life of a Custom Mowing contractor #1,654
Hay Dude, Isn't that batwing that you use a rotary cutter? And you bale after cutting with that? Or am I mistaken and you have other cutters for your use with the large square baler? Just curious, as that's what it looked like to me. Thanks Greg
   / The Life of a Custom Mowing contractor #1,655
I think he uses that for the tracts he mows that don't or can't get baled. He has quite a setup for baling/conditioning.
Yes, the John Deere CX-15 I have is a 15’ rotary cutter.
No, it’s not used to cut hay fields. It’s used to cut non-hay fields.
The John Deere CX-15 Batwing rotary mower is used to mow fields that are not hayed.
Like this:
When we cut/bale hay, I use the Massey Ferguson 7495 with the (2) Pottinger hay mowers. They have a completely different mowing process than the John Deere CX-15.
These mowers have several smaller “disc” mowers and the conditioning tines you see underneath the mower.
Here’s the mowers lowered into cutting position. Cuts a 21 foot swath.
   / The Life of a Custom Mowing contractor #1,657
Like this:
Thanks for clarifying that - now that you did, I do remember seeing the other mower on the Massey. You've got so much equipment it's kind of difficult to keep each piece on track at times! Thanks!!
Got the green light to start trucking hay to 2 of my mushroom hay buyers.
Here’s 16 biscuits I delivered this morning.
13.5 tons.
Scale said 47,500lbs. Can’t do that with a Ford. :)
Started mowing 2nd cutting yesterday. This field already overrun with foxtail. The deer decided to wait until the last second before I mowed right by him. I swear these deer are semi-domesticated round here…
   / The Life of a Custom Mowing contractor #1,659
13.5 tons.
Sure they are HD, but cock a rifle and their meaning to life comes to the forefront . . . ;), nice load btw :).
Thanks! :)
I trucked 4 loads like that in this week.
205028 (A52706)
205028 (A52706)
Case SC Tractor (NOT RUNNING) (A50775)
Case SC Tractor...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
UNUSED JCT 72" HYD VIBRATORY PLATE COMPACTOR (A54757)
UNUSED JCT 72" HYD...
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
