T233 Driveshaft Question
/ T233 Driveshaft Question #1
.50AE
T233
Hey guys I purchased a non-running T233 a couple weeks ago and finally got it running good. Problem is that it was making this awful noise underneath so I checked it out and it looks like the driveshaft is off of it. Was reading into it and looks like it's a common problem with these earlier models. Splines on the HST look fine. Did some digging and came up with a part number of "13182102100" but it says it's for a T273. Everything points to that they use the same driveshaft. Just wanted to double check with the TYM gurus and make sure it's the right part before I order.
/ T233 Driveshaft Question #2
Same parts on the 233, 273, and I think the 293. All have the Mitsubishi S3l engine in various displacements, and injection pump setups. The 233 and 273 share the parts manuals.
Good luck getting the parts from TYM. Seems everything coming from Korea is slow.
Awesome, thank you. I found a few different sources for the shaft other than TYM. Couple ebay sellers and various online stores all seem to have them. Around $350 though sadly.
/ T233 Driveshaft Question #4
do you have the manuals? Not sure how to get them to you, but I have digital copies of the Owner/Operator, Repair/Maintenance, and Parts Manuals, if you want them.
And a lot of the T25 parts work on the 233, 273, 293. Front Axles are the same, the transmission internals, 3pt parts, etc, Transmission case part number is the same except for the last letter, all the internal I checked were the same. And teh rear remote valve is teh same.
Yes it looks like the driveshaft is the same part number across all the smaller engine models. I found the manuals online. Thank you for the offer though.
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
Unused 12-16.5NHS Skid Steer Wheels and Tires (A61572)
Unused 12-16.5NHS...
2017 Chevrolet Express 3500 14FT Box Truck (A61573)
2017 Chevrolet...
3pt 6 Row Cultivator (A64119)
3pt 6 Row...
John Deere Z997R (A60462)
John Deere Z997R...
2021 Harley-Davidson FLHP Road King Motorcycle (A61574)
2021...
