Wire feed issue with Lincoln 175 mig
/ Wire feed issue with Lincoln 175 mig #1
scootr
Super Member
Temecula California
Kubota MX5200 HST, 773 Bobcat, Cat forklift
The Lincoln 175 is a 15 yr old welder having seen moderate use. Issue is slow or no wire feed. Things I've checked:
tensioner, spool tension, tip.
I'm untrained but it seems like a feed motor issue as after just a short bit it seems to strain and slow down or even stop. But I could be completely wrong
/ Wire feed issue with Lincoln 175 mig #2
Scootr,
Remove the liner from the gun and see if it still feeds slow. If it does it could be the tension, or feed motor.
Also see if you can pull the trigger and stop the wire by holding back the spool of wire, if so increase your tension.
I have always used wire lubricant which makes things go smooth.
Good luck
/ Wire feed issue with Lincoln 175 mig #3
Did you replace the spool of wire? Is the wire tangled on the spool. BTDT.
/ Wire feed issue with Lincoln 175 mig #4
Check that your wire drive wheel is the correct size for the wire your using.
If its to large the wire will slip.
/ Wire feed issue with Lincoln 175 mig #5
IF all the above items fail to show the trouble, you could pull drive motor assembly and test it with a 12V battery, most MIG welders use a drive motor the can range from 9 to 18 volts dc....
/ Wire feed issue with Lincoln 175 mig #6
Ensure that the wire is being pulled from the correct spool direction.
/ Wire feed issue with Lincoln 175 mig #7
If you can watch the drive wheels while it's happening and see what is slowing down that would be helpful... If you've never changed the liner I would lean to that, chances are there's some buildup in there that might be binding that is assuming the wheels on the drive are spinning when the wire stops or slows... Feed motors should be available for that I would imagine but liners are cheap and available.
/ Wire feed issue with Lincoln 175 mig #8
We had some trouble with smaller wire feed machines where I worked. It ended when the drive rollers were changed with the wire type. The manufacturer recommended grooved V rollers for flux core and non-grooved V rollers for solid.
/ Wire feed issue with Lincoln 175 mig #9
I have the same welder and if running core flux it's a little finicky on the brand. Lincoln/Hobart I have never had any issues. HF I've had issues with it lodge up in the nozzle. The thickness was so variable I ended up just throwing the whole spool away..
/ Wire feed issue with Lincoln 175 mig #10
I paid $25 for a HF MIG-180 where the guy gave up trying to make it feed properly. After he tried every mod he could think of, to make it feed smoothly. I put a brand new grooved feed wheel in it for my flux core use and now it feeds fine.
I suspect tightening the feed wheel tension excessively, trying to improve traction, crushes FC wire out of round (or makes burrs) so then the wire gets stuck in the nozzle.
I thought I had it fixed but last night it was acting up again...I'm going to have to get serious about fixing this. Thank you all for the great suggestions. I will report back if I find anything particular. FYI. It's a 15 yr old machine. I did replace the liner once but can't remember how long ago that was so ? I did lend it out and it came back with a new spool and bottle on it. Base on that it got hell of a lot of use ...
Progress, straightening out the stinger had some effect on the feed. I ordered a new stinger. Will double check the feed when the old one is off and let you know if this fixes it...fingers crossed.
