L5030 engine oil leak
/ L5030 engine oil leak #1
dbainbridge
L5030
My L5030 has a slow oil leak somewhere at the front of the engine. The oil has leaked enough over time that the radiator fan has caused the oil to splatter across front of engine and even out the right hand side vent of the bonnet cover. There is also some oil that got onto bottom of radiator itself and collected dust/dirt. When I park the tractor after heavy use there is probably a tablespoon worth of oil that drips onto the ground. I'm having trouble determining where this engine oil leak is coming from. Any ideas how to identify where it is from or if there is a common gasket that needs to be replaced? If I recall correctly the tractor has less then 1500 hours.
/ L5030 engine oil leak #2
Pressure wash your engine, specifically the front, trying to get every nook and cranny without bending the fins on your radiator, and stay away from wires, you know they don't leak. Run the engine to temp, shut off and inspect carefully with a mirror and flashlight. A lot of Kubota engines, diesel and gas both, have a wierdly placed "bolt" in the timing cover that likes to leak. This "bolt" has a vertical notch cut into it, so only the last few threads actually seal in the timing cover. Usually located right side, towards the top of the engine. Pull it out, brake clean it and the hole, you wont get too much brake cleaner in your oil if your careful, and use Permatex aviation gasket maker and a thread sealant. I have fixed this leak on generators and water pumps, although not to a tractor, yet...
/ L5030 engine oil leak #3
gengine is probably onto something for the source of your leak. Experience is worth a lot! I would remove as much obstructive sheet metal and coverings as I had to until I could see where the leak is. One should be able to find the leak by inspection if you can uncover the location. There are all sorts of other possibilities like seals but with a ball park 1500 hrs that seems unlikely.
/ L5030 engine oil leak #4
front seal leak? after engine clean, run until you notice leaking, maybe use talcum powder to identify source. best of luck. thinking front seal leak much better than rear?
Does someone have recommendation for an electric power washer? Don't have one to clean it up with.
Here is some pics.
Top of engine is clean of oil:
Definitely seems like more oil collected on the part underneath the air intake hose:
/ L5030 engine oil leak #6
Well, yeah, but I could also think that there was just as much oil on top of the engine but it dried up due to higher heat in that area. The accumulation under/around the air intake hose may be because of getting trapped there when thrown back from the fan and not dried out/burnt off because of lowwer temps there. Say, does this 5030 have an oil cooler by any chance in front of the radiator?
I can say with certainty there was never oil on top of the engine. I've had the tractor since new. There is no oil cooler. Going to see if can identify that one part.
/ L5030 engine oil leak #8
Here is some pics.
I've on my third electric power washer. The one that finally lasted - and still does - is from Home Depot.
2300 psi/1.2 GPM Ryobi. has wheels and looks almost like a gas powered one. Model is their "Premium Electric". I Think it cost a little over $200 a few years back plus whatever I paid for the extended warranty.
Works well & has a soap dispenser.
I don't usually buy Ryobi tools, but this one has lasted.
/ L5030 engine oil leak #9
I’ve had good luck with Ryobi tools too, especially for jobs around the property. The 2300 psi Ryobi electric washer sounds perfect for cleaning the engine area so you can pinpoint the leak. Once it’s clean, check common spots like front crankshaft seal or valve cover gasket for seepage.
/ L5030 engine oil leak #10
I finally found my hose leak by power washing the area, quickly drying it with rags, and then following the occasional drip up to the highest point. Sure enough, there is a tiny pinhole in the rubber hydraulic hose cover. Not where anything can touch it, so probably manufacturing defect.
Luckily it is on the backhoe thumb return line and doesn't see constant high pressure. but it is amazing how that little seep can oil a whole area given enough time.
rScotty
Okay. After getting a power washer and cleaning everything up (except the radiator which is still a mess) I found what the issue is. I had the tractor in to a Kubota dealer several years ago because it was getting hard to start and sometimes wouldn't start at all. They could never figure out the root issue but removed the stop solenoid and added a manual cable with lever to start and stop the engine. The problem was that they only partially covered the hole where the stop solenoid was with a strip of metal so at least half of the opening was still completely open to the air. Needless to stay I realized oil would spurt out of this hole likely at higher rpms. I used a round piece of metal (electrical conduit knockout plug) and covered the entire hole. Gasket was also still there. I baled some hay today and engine area stayed completely clean of oil and no oil leaks. Sort of upsetting that the dealer did this.
What would be best way to clean the radiator with that gunky oil on it?
/ L5030 engine oil leak #13
I'd try one of the foaming AC cleaners. Pay attention to the labels some say keep away from rubber components and wires.
John Deere 74in Bucket with Bolt on Cutting Edge Skid Steer Attachment (A61567)
John Deere 74in...
2022 John Deere Z920M Zero Turn (A63116)
2022 John Deere...
1993 Generac Olympian 93A 02255 50kW T/A Towable Diesel Generator (A61567)
1993 Generac...
Rogator RG1100 (A63118)
Rogator RG1100...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2018 Ford F-150...
SKYJACK SJ86T TELESCOPIC BOOM LIFT (A62129)
SKYJACK SJ86T...
